Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune door lock
When I press the start button "door lock" comes on. However the door can be opened. I pushed off and start again and the same thing happened. I unplugged it and plugged it back in and the same thing again. What to do?
  • siva1 May 05, 2009
    door lock sensors cost $400
You need a new door lock switch
Posted on Aug 07, 2008
My Maytag Neptune front load washer door won't lock.
Hi Frances, from what you are describing it sounds like he check switch in the door lock assembly has gone bad. It isn't acknowledging that the door is fully locked and the control board thinks the door is still open. Fairly inexpensive part but labor Ivan be a pain to replace the check switch. Hope that helps.
Jun 05, 2017 | Maytag Washing Machines
I have a maytag neptune modle mah8700aww the door won't unlock
Getting rid of the Maytag Neptune is the only solution!
Feb 14, 2010 | Maytag Washing Machines
The lights go on, but washer will not start.
door not closed try open door and then closing again
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer will come momentaraly
There is a door locking unit that should lock when you press go. This must have failed. It lives just under the lid in the middle at the front. It is thermal piston, when you press go it gets power and extends. When it hits a micro switch that tels the washer the door is shut and allows it to continue, else it shuts down. To get at it you have to take the front off, leave the door on.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune washer MAH-1 start button turns off, does not spin
Hi!
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
Thanks
Rylee
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Door Load, Problem
Hello Yery1975
Welcome
You said, you have a situation with my washer machine (Maytag Neptune front loader). It was making the noise several times as latching the door, then if would go off and you could not open the door, You found the under soap deposit cord but the situation is not opening the door or no, it is getting he machine to work. Whichever cycle you press, the door makes the locking noise several times, sometimes the door can not be opened and the lock door light is off, the thing is that whichever cycle you try the numbers on the electronic pad would go down several numbers and then it will again make the door locking noise and will stop there, the start button begins flashing and the machine does not wash at all on any cycle, neither it spins or rinses. Can you please, please, help me? Ohooo... some times after trying and trying get the FL code... you have tried keeping it disconnected from the electricity for long periods, plugging it back and all you can think off.... but nothing!!!
You did the right thing
The Maytag Neptune had a lot of very different defects that Maytag was, and is aware of still.
That is why they discontinued that model .
But if you call Maytag service this time, you may find that it will be one of those defects in their design and an authorized Maytag person will recognize which fault is taking place.
perhaps they may cover the parts if you bring it to their attention.
Thank You
Please remember to leave a rating
Oct 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MAH5500B Front Load Washer Logo
798 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
