Question about HP PSC 1315 All-In-One InkJet Printer
Paper Jam I was trying to print photos on my hp psc 1310 when one of the 4x6 glossy photo paper jammed. How do I remove it? Thanks Karen
    Novelist:
  • 180 Answers
  1. Press the On button and then unplug the power cord.
  2. Press in the tab on the rear door to release the door. Remove the door by pulling it away from the unit.
  3. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  4. Replace the rear door. Gently push the door forward until it snaps into place.
  5. Plug the power cord in and then press the On button to turn the unit on.
  6. Press OK to continue the current job.
Posted on Aug 06, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hello, I have a HP PSC 2335 all-in-one printer and it won't let me print on photo paper. Is there a certain setting that I need to change for it to let me? Every time I try and print it says there is a...
No setting would do that - the error is generated because the photo paper is more slippery than what the rollers can handle so they skid and the difference in their rotation triggers the jam warning message.
Just use a different brand of paper, less glossy.
Jun 02, 2011 | HP PSC 2355 All-In-One InkJet Printer
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
Paper jam in hp psc 1210v all in one printer/scanner/copier
Check for any obstacle in the Outlet of Printer or Paper input area
Which dp size paper u r using try with different photo paper
Jun 01, 2010 | HP PSC 1210v All-In-One InkJet Printer
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Hi, Is there any way of clearing a paper jam when the paper is completely inside and out of reach?! The machine just tries to clear it but nothing happens! It a piece of glossy photo paper and won't catch.
just open the cover the printe head will come to center disconnect the power cord and remove the catridge and then roll the roller manually and pull the paper out.
Jan 25, 2010 | HP PSC 2355 All-In-One InkJet Printer
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
Problems with printing photos. Hp Psc 1410
check the configurations again, if the problem were still there, try with other cartridges.
Aug 13, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
124 people viewed this question
Ben Johnson
