Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Turn the main power switch(on the main unit's right side)off and on again. error code E000000-0000
  • 113 Answers
Check the power supply first. is there any voltage fluctuations? Go to service mode. Addl. function>2&8>Addl. function> select copier. function>clear>err>ok. switch off the machine, wait for 15 minutes & turn on
Posted on Apr 09, 2011
Where can i find the fusing unit with pictures about c-3102 bizhub c650
The fusing unit is located on the right side of the machine, open the right side door, not the duplex door the bigger one. you will see a shinny belt do not touch as that puts the image on the paper. The fuser unit is right above it. It can be hot so power off to remove it. your code is for the fuser did you try to reset it??
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jan 03, 2017 | Konica Minolta BizHub C650 Copier
How can I correct error code c3822 on bizhub C451
1. Turn OFF the main power switch (Inside front cover). Ensure sub power switch is on located right side of the control panel)
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. If the code come back do NOT reset have a tech come out replace the fuser unit, it can catch on fire that will ruin a Christmas Day!!!!!
Nov 08, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
My konica minolta printer C650 series PCL has an error code of C-3425
Sir/Mam, turn off the main power switch(INSIDE), ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it see a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Aug 19, 2015 | Konica Minolta Office Equipment & Supplies
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
Hi there
On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format.
The page is here and carries all the error codes
Error Codes Canon iR2520
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
C-3725 trouble code
The fusing unit in side machine has reached a very high temp. This is the unit which fuses the toner to the paper the hot part upper right hand side of the machine. to reset follow:
Utility
1.Power off the machine using the main power switch inside front door leave sub power switch on that's the one on the op panel side.
2. Hold down the Utility/counter button.
3. Power on using main power switch and close the door.
4. wait for screen to show trouble reset touch trouble reset chk for OK
5. turn off main power switch, wait 10 seconds then power it up again. it should restart and go ready to copy. if the code comes back do not reset the machine again. It is informing you there is a problem get it looked at.
Jun 01, 2014 | Konica Minolta KONICA BR BIZHUB C451...
ERROR CODE C-3852
Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit/ High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Feb 06, 2014 | Konica Minolta bizhub C250 All-In-One...
C3452 error code bizhub c352
Sir/ Mam,
If after this procedure the code comes back do not reset again, get a tech out and expect to pay for a new fuser unit, continue resetting can cause the fuser the hot part to catch on fire ruining a perfectly good day.
1. Turn OFF the Main Power Switch (Located in side front cover). (ensure Control panel power switch is on)
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
Jan 10, 2012 | Konica Minolta Office Equipment & Supplies
E000732-0001 Error Message
E732 Error code details
  Main cause
 The cable connector has poor connection. The reader controller PCB is faulty.
Condition
 0001 The main controller PCB detects a fault in the communication between the reader controller PCB and the main controller PCB. Connectors
1) Connect the cable [1] for the environment heater.
ir7200-f04-309-01_e.png 2) As needed, connect the reader unit anticondensation heater cable [1].
ir7200-f04-309-02_e.png PLS RATE ME!!!!!!!THANKS MATE.
Sep 23, 2009 | Canon imageRUNNER 8500 Copier
Error code sc548
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps.
Jul 08, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
BizHubC253 error code c3821
This error also occurs after a paper jam or a steep power change. If error continues after doors were properly closed and the printer was turned off and on again, it'd be necessary to reset the printer and release it from trouble status.
Turn off the main switch (1/0 botton) but keep the control panel on. Wait 10 seconds. Press and hold Utility Counter botton on the Control Panel while turning on the main switch. Hold it until a white screen with a black dot over the upper rigth corner appears, then release it. Wait for a "trouble reset" botton on the control panel and then manually click on it. You'll see an arrow pointing to an "OK". Now turn off again the main switch, wait 10 seconds, and turn it on. Error must be gone.
May 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
1,192 people viewed this question
old marine
old marine
