Question about APC SURT1000XLI 1000VA 700W 230V UPS (SURT10000XLI) UPS System
Battery AH & TOtal battery qty - APC SURT1000XLI 1000VA 700W 230V UPS (SURT10000XLI) UPS System
    Problem Solver:
  • 9 Answers
4 batteries 12v-7ah
Posted on Apr 19, 2011
Can I put higher Ah batteries in my Shoprider Streamer?
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
Jun 09, 2014 | Shoprider Streamer Sport Power Chair
Ris 2d s7Hello. This is Sung ah, Jo from Asianlux Company,food service equipment in Korea. My customer korean air are using this machine.VICTORY RIS-2D-S7-GDThey told me the door doesn't work well.
Hello honorable lady. Please see these links
Victory RS-2D-S7 Parts & Manuals ' Parts Town
www.partstown.com/victory/rs-2d-s7/parts
  1. Cached
  2. Similar
Find genuine OEM Victory RS-2D-S7 replacement parts at Parts Town with the largest in-stock inventory and same day shipping until 9pm ET.
Victory 50616802 COILEVAP84E21 ' Parts Town
www.partstown.com/en-ca/victory/vt50616802
  1. Cached
Find Victory 50616802 COILEVAP84E21 replacement part at Parts Town with fast same day ... Documents for RA-2D-S7-GD: ... Documents for RS-3D-S7:.
Victory Refrigeration Parts & Manuals ' Parts Town
www.partstown.com/victory/parts
  1. Cached
  2. Similar
Parts Town has the largest in-stock inventory of genuine OEM Victory Refrigeration parts with fast same day shipping until 9pm ET. Find the part you need today.
Owners Manuals - Victory Refrigeration
www.victoryrefrigeration.com/technical-service/owners-manuals
  1. Similar
A description for this result is not available because of this site's robots.txt Learn more
VICTORY RIS 2D S7 GD Google Search
Jun 22, 2017 | Refrigerators
I have a Olivetti ECR 100 EV . To reset the date the instruction says i need a X/Time key. But i only have a Qty/Time key, and this does not work. I can't reset the date. Can you help me?
hi to set the time slide the switch to z then press RA then enter the time as a 24hr clock, then press QTY/TIME then press Sub Total. and its done
Mar 16, 2012 | Computers & Internet
A shortage of 100 kgs in chemical A, of 140 Kgs in chemical B and Of 50 kgs in chemical C was noticed due to breakages. At Mumbai, the manufacture paid octroi duty @ 0.20 kg. He also paid hamali, Rs 20 for...
CASE STUDY - 1
Chemical A
Chemical B
Chemical C
Qty(Kgs)
Rate (Rs.)
Amount(Rs.)
Qty(Kgs)
Rate (Rs.)
Amount(Rs.)
Qty(Kgs)
Rate (Rs.)
Amount(Rs.)
Cost of Chemicals
6,000.00
4.20
25,200.00
10,000.00
3.80
38,000.00
4,000.00
4.75
19,000.00
VAT
630.00
950.00
475.00
Railway Freight
300.00
500.00
200.00
Octroi 2%
504.00
760.00
380.00
Hamali
20.00
58.12
30.75
Total Cost
6,000.00
26,654.00
10,000.00
40,268.12
4,000.00
20,085.75
Less: Shortage
-100
-140
-50
Net Qty Received
5,900.00
26,654.00
9,860.00
40268.12
3,950.00
20085.75
Normal loss
-236
-394
-158
NEED ANSWERS CONTACT ME AT aravind.banakar@gmail.com M : 09901366442 / 09902787224
Aug 30, 2011 | Computers & Internet
Is there any diffrences beetween ytx7 a-b s battery & ytx9 b s battery?
Yes, the size.
YTX 7 is 6 Ah.
YTX 9 is 8 Ah.
Both are made in China.
Apr 17, 2011 | Factory bike Desert YR 250 Motorcycles
How do you check the battery status?
Check battery voltage using Volt meter=> it should be about 12.6 to 13.8 vdc.
Pull the battery out... checking the deforming at the case ..such as "swelling"... if yes .. replace the battery.
Replacement battery is about 10-20 dollars on e-bay (watch for shipping charge and size. and terminal connection sizes )
The average life of battery on UPS is about 5-7-10 years wi)th UPS plugged in (Charging
One I had my local Autozone checked my 12 VDC -8 AH ... ask them to set CCA at about 100 AMP...
for 12 VDC -14 AH ask them to set CCA about 200 AMP.
For a 12 VDC -75 AH (group 24) they set the load on their tester at about 700-900 CCA.
You can also buy a manual battery load test at Harror freigt tool for about $20 US dollars (On sale)
Feb 18, 2011 | APC Back-UPS ES 350 - UPS ( external ) -...
WHAT SIZE BATTERY DO I NEED?
Hello! 750 cold cranking Amps (935 cranking Amps)...Example...Duralast Gold...Part Number:24-DLG
Guru.........saailer
Feb 05, 2011 | 1997 Nissan Pathfinder
I need the product specifications for this model
hi,
u didn't specify any model. any how i am senting speck of the following model. if u have selected model in ur mind, just contact me through fixya. will sent u the specification.
dotclear.gif Olevia 232V General
  • Product type LCD TV
  • Diagonal size 32.0 in
  • Viewing angle 178 degrees
  • Viewing angle (vertical) 178 degrees
Video
  • Technology TFT active matrix
  • Resolution 1366 x 768
  • Display format 720p
  • Image aspect ratio 16:9
  • Pixel response time 8.0 ms
  • Progressive Scan Progressive scanning (line doubling)
  • Widescreen Widescreen
  • Widescreen modes Panorama,
    Full,
    Conventional 4:3,
    Zoom
  • Dynamic contrast ratio 1600:1
  • Comb filter 3D digital
  • Color temperature control Yes
  • HDCP compatible Yes
  • Supported DTV resolutions 1080i,
    720p,
    480i,
    480p
  • Supported computer resolutions 1360 x 768
TV Tuner
  • TV tuner presence Yes
  • Tuner qty 1x analog/digital combo
  • Digital TV tuner ATSC
  • Analog TV tuner NTSC
  • Secondary audio program (SAP) Yes
Audio
  • Sound output mode Stereo
  • Total output power 20.0 Watt
  • Speakers 2 speakers
  • Speaker system speaker type Right/left channel speaker
  • Additional features Auto volume adjustment
  • Speaker form factor Built-in
  • RMS output power 10.0 Watt
  • Speaker system speaker qty 2.0
  • Audio controls Bass,
    Treble,
    Balance
Convenience Features
  • Closed captioning Yes
  • Parental channel lock Yes
  • V-chip control Yes
Connectivity
  • Video interface S-Video,
    Composite,
    Component,
    HDMI
  • HDMI ports qty 1.0
  • PC interface VGA (HD-15)
Remote Control
  • Type Remote control - Infrared
Power
  • Power device Power supply - Internal
  • Power consumption operational 180.0 Watt
Dimensions & Weight
  • Dimensions (WxDxH) 37.8 in x 9.4 in x 22.2 in
  • Weight 35.5 lbs
Manufacturer Warranty
  • Service & support 1 year warranty
  • Service & support details Limited warranty - Parts and labor - 1 year
Dimensions & Weight (Shipping)
  • Width (Shipping) 42.8 in
  • Depth (Shipping) 12.4 in
  • Height (Shipping) 25.4 in
  • Weight (Shipping) 45.4 lbs
Sustainability
  • ENERGY STAR Qualified Yes
Dec 14, 2010 | Olevia Televison & Video
I have XL8 and need to replace batteries, what is the amps strength to give me greater miles, Im a big guy and need to go further than just a few miles
hi, according the manual
http://www.pridemobility.co.uk/docs/UK_Celebrity_XL8_om.pdf
the batteries are
Battery Requirements
Size: U1 (31-36 AH)
Weight Capacity 181 kg, 28 stone (400 lbs.)
Range Per Charge1 (With 31-36 AH batteries) Up to 40.23 km (25 miles)
You can use 40Amps batteries for this scooter and that will increase the total distrance to 27 miles max depending on your weight.
Regards
GeWiz
Jan 18, 2010 | Pride New Mobility Legend 4 Wheel Scooter
In Excel
   a                         b                 c                    d
1 item                     cost            qty                 =c1*b1
2 item                     cost            qty                 =c2*b2
                                                 total              =sum(d1.d2)
all quantities should be blank except for the items you want to total.
Oct 25, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
APC SURT1000XLI 1000VA 700W 230V UPS (SURT10000XLI) UPS System Logo
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
