Question about Speed Queen Dryers
How do i remover the exterior cover from the dryer, i have marathon heavyduty machine
    Sergeant:
    Champion:
  • 207 Answers
Well if its standerd front loader filter on top u take the filter screen out remove the two screws then with a flat screwdriver push along the front top seem pull it up it should give way and pop up the newer model's and some older take back off.
Posted on Apr 09, 2011
Rheem marathon tripping breaker
Turn power off. Open covers and inspect for burned parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 27, 2012 | Rheem MSR50245 Marathon Electric Water...
I have a wdr1242 washer dryer the dryer seems to take forever to dry clothes sometimes 2 hours or more even for just half a dozen socks
If your dryer is still heating up; Check the dryer vent hose, also check down inside where the lint screen goes. If no lint is obstructing there, check the exterior dryer vent. Sometimes you have a screen to keep birds and rodents out of there, and may become clogged with lint. If no screen, check inside the flap, maybe someone moved in, or dryer lint is clogging up your exterior vent.
Dec 08, 2010 | Tricity Bendix WDR1040W Front Load Washer...
My kenmore 110.67422600 does not have heat i checked the house breakers and no joy. I am curious how to troubleshoot this.
hi,
the most usual culprit is the dryer element. they are pretty easy to replace on kenmores. hopefully their design is the same. I will walk you through it.
unplug the machine and remove the rear cover, there are screws along the circumference. now with the rear cover removed your looking for a grey metallic box that about 2 feet long. this is your element box and the element is inside. mark the red wires and the sensor wires with masking tape and remove the wires from the sensors and bottom. remove then remove the box with a couple more screws there. take the box and put it on a flat surface. on the exterior of the box is one or two more screws to remove the element from the box. pull the element out of its box and replace it. you can buy a replacement at an appliance store or look online. while your inside of the machine use a flashlight and get as much lint out as you can. never run you dryer and leave your house either. never run dryers unattended, just some advice. good luck!
jm
Jul 29, 2010 | Kenmore Dryers
Removing exterior panel covering track for center roller on sliding door
exterior panel is not removable. to access center roller,remove screws & clips from interior door trim panels remove roller cover panel inside door.loosen bolts to adjust roller,remove bolts to replace it.
Oct 13, 2009 | 1992 Plymouth Voyager
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Belt broke
If you can see the belt and there is not a cover under your machine, you can simply remove the belt and replace. However if you have a bottom cover, you will have to remove all exterior screws around the front and sides of the machine. There are several, this will release the cabinet so that you can remove the cabinet and get to the belt to remove and replace.
Jul 05, 2009 | Amana DLW330RA Top Load Washer
Replace left front door outside handle pot metal tip broke off
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual REMOVAL AND INSTALLATION Exterior Front Door Handle Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Position the watershield aside.
  1. NOTE: The tie strap does not need to be reinstalled.
    If equipped, remove the tie strap from the anti-theft guard.
  1. Remove the screws and position the anti-theft guard aside.
  1. Release the clip and disconnect the exterior door handle actuating rod.
  1. Remove the anti-theft guard.
  1. Remove the exterior door handle screw.
  1. Remove the exterior handle actuating rod.
  1. Remove the exterior door handle lock cylinder cover.
  1. Remove the exterior door handle.
Apr 25, 2009 | 2001 Ford Escape
Replacement of Mirror/Assembly, 2004 Ford E350 Super Duty
Exterior Mirror Removal and Installation
NOTE: Aero mirror shown, dual arm similar.
Manual mirrors
  1. Remove the mirror sail cover to gain access to the exterior mirror retaining nuts.
Power exterior mirrors
  1. If equipped, remove the front door speaker.
  1. Remove the front door watershield.
All exterior mirrors
  1. Remove the rubber plugs and dust shield.
  1. Disconnect the electrical connector(s).
    1. Disconnect the power exterior mirror electrical connector.
    1. If equipped, disconnect the heated exterior mirror connector.
  1. Remove the nuts and remove the exterior mirror.
  1. To install, reverse the removal procedure.
Jan 08, 2009 | 2007 Ford E-350 Super Duty Length XLT
Hi, I have a Maytag gas Dryer, Legacy series, heavyduty. I clean the lint filter each time used but there is still a build up which I cannot get out unless I remove the filter housing. How do I do this?
you do not have to remove the lint housing all you have to do is go to an applaince store and ask for a lint brush you then take the lint brush and shove it down where the filter goes to loosen the lint turn on your dryer and it will blow it outside
Dec 26, 2008 | Dryers
How do I open the dryer to replace a loose belt?
there are 2 clips holding down the main top, approx, 3-4 inches in form each side of the main top where it meets the front panel. With a flat blade screw driver or a putty knife, youll be able to "pop" the clips and tilt the top backwards, form there there ar3 2 5/16screws holding hte front panel on within hte machine.
Nov 24, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
277 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
