While photocopying black shadow impression come all over the paper.
2 Suggested Answers
Aneesh AM
  • 56 Answers
SOURCE: when photocopying, leftside print missing/text
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve....
before that pls. check your cartridge unit...
Posted on Apr 24, 2010
I have a canon ir 1018j black and white photocopier that does not pick a paper nor photocopy
If the problem is simply that the machine is not feeding paper, you should clean the paper pick up and feed rollers. Typically there will be one attached or above the paper tray(s) and a couple that transfer the paper through the machine to the print drum and fuser. Find them and clean them with clean cloth wet with a dilute solution of dish wash detergent with a few drops of methylated spirit or isopropanol mixed in. If paer then feeds but no print - you have more serious issues.
Sep 05, 2016 | Canon IR1018J Black and White Copier
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
When photocopying, leftside print missing/text
Apr 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
The best paper for the Lexmark X1270 printer
Hello. Your first consideration is paper weight. All printer paper, inkjet included, is measured in gsm or grammes per square meter. A very lightweight paper for your inkjet printer would be 60gsm. When you walk into any store and buy a **** (500 sheets) of inkjet paper you'll find that the stock on display is 80gsm. This is a general purpose weight paper suitable for photocopiers, inkjet and laser printers.
What if you need a heavier weight paper? This shoulnd't pose a problem in any well stocked office supply or computer store. Inkjet paper also comes in 90gsm, 100gsm and higher grades. You'll find that heavier papers give you crisper text and less ink bleed also. Do bear in mind that every inkjet printer has a maximum paper thickness it can handle. If you're buying paper in weights of 110gsm - 125gsm consult your printer documentation before you feed very heavy paper through it - otherwise you risk seriously damaging your printer.
Apart from the weights you also have a wide variety of styles. Paper for your inkjet printer can also be purchased in bright white variants. These are designed for single sided printing of important documents or presentation pages. This type of paper is more expensive but if your goal is to impress then it's money well spent as ther results are truly impressive.
Apr 19, 2010 | Lexmark X1270 All-In-One InkJet Printer
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
No gradition
try replacing the transfer belt cleaning blade.
Apr 14, 2009 | Canon imageRUNNER C3200 Copier
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Not photocopying
Open side, look at black assembly on the door, there is either a black spongy roller there or two wires in a black assembly,
1- wires may be broken resulting in blank copies
2- roller out of place
3- HVT (high voltage transformer) not working
Jun 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
29 people viewed this question
k24674
jasbo
jasbo
