Question about Samsung Galaxy S Captivate I897
I've had my new Captivate for 2 weeks, and at first the travel adapter worked for charging, but now i can only use the USB port on my PC to charge the phone. Is this a problem with the phone's settings or the travel adapter itself?
    Problem Solver:
  • 15 Answers
If you are able to charge the phone via USB then the problem lies in the travel adapter.
Posted on Apr 09, 2011
My Samsung Galaxy S Captivate has a loose charging port. It will not charge unless I push up on the cable at the exact right spot. How can I fix this?
Maybe try using a different USB connector. It may not be your phone, but the wire or wall plug itself. If that fails then I'd suggest taking your phone into a phone repair store to get your charging port replaced. The same thing happened to me and I took it up to foxpaw and it was only about $50. A new USB cord is around $5 at any walgreens or gas station.
Apr 11, 2015 | Samsung Captivate Cell Phone
Where can I source an new a.c. adapter for my craftwell e bosser
Search for a Travel Laptop Adapter or Universal Laptop Adapter. Targus makes one with several different tips. Targus Laptop AC DC Travel Charger with USB Fast Charging Port USB...
Aug 27, 2014 | Computers & Internet
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
Jul 26, 2014 | Apple iPad 32 GB WiFi Tablet PC
Cigar (accessory) port will not provide power via a USB adapter.
Have you tried the adapter in another car? It could be that the ground post is reversed in your adapter and the phone is safeguarding the power flow. A diode installed backwards in the adapter would prevent current flow.
Apr 26, 2013 | 2000 Ford Escort
Samsung s duos wont charge
even i have got the same problem. Its two weeks old and is not getting charged. I.ve tried both the regular charger and the usb cable to charge it. Guess will have to take it to the service station.
Mar 02, 2013 | Samsung Galaxy S Duos S7562 White Dual SIM...
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
Charging the mp3mp4 player
  1. Get a USB wall charger. These are AC adapters that plug directly into the outlet. You then plug the USB from your MP3 into the port on the adapter.
  2. Charge your MP3 player on the go. There are also charging kits that plug into the cigarette lighter or power plug in your car. These kits come with a DC power adapter that has a port on the end for you to plug in your MP3.
  3. Acquire Apple iPod specific chargers. When you need to charge your iPod music player through an outlet, look for the Universal USB car charger or the Universal USB travel charger made specifically for Apple products.
Make sure that you have your player on a power strip or surge protector so that if you get a surge you wont fry your player.
Sep 27, 2009 | Audio Players & Recorders
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
E280 not charging
You might have to get a new charger--But be careful. If the charger isn't made especially for the Sansa e280 there's the possibility of it messing up the mp3 player itself.
It could also be your computer's USB port. Try using a friend's computer or a different USB port perhaps and see if it works then.
Apr 07, 2008 | SanDisk Sansa E280 MP3 Player
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
Open Questions:
Samsung Galaxy S Captivate I897 Logo
70 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
