Question about Sony PlayStation 2 (PS2) Console
Ps2 when i turn on my thin ps2 game and put in disc and then press play it reads there is no data, what do i do
Have you tried cleaning the disk you can go to walmart or another major department store and get disk repair kits and clean the disk
Posted on Aug 08, 2008
SOURCE:
When i put in a game in my ps2 it says reading for a few seconds and then the reading disc sign disappears and the game doesn't turn on. What should i do?
Try playing a movie and make sure the disc is clean, if the PS2 can not read any disc, is because the ps2 need to be serviced, but it might not be worth it.
Jan 15, 2011 | Sony PlayStation 2 (PS2) Console
I was just wondering, IF the PS2 can play games that have been edited on a computer/laptop (e.g. 4-disc PS1 game put onto one disc), and not edited as in the actual game disc being edited, but put on a...
Your system needs a mod chip to play games on a disc that was not created by Sony.
Most ps2 games are DVD's only some are cd's.. All of the ps1 games are cd's so if you burnt it onto a dvd its not going to work.
Oct 06, 2010 | Sony PlayStation 2 (PS2) Console
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
How to fix my playstation 2 that won t read grand theft auto san adreas
Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home....
You can also follow these steps to make your PS2 to play GTA San Andreas:
  2. On menu screen go to [options] by pressing 'triangle' button.
  3. A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
  4. Then insert the game disc.
  5. Turn off your PS2.
  6. Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
Nov 19, 2009 | Sony PlayStation 2 (PS2) Console
Wont load
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
If your PS2 can not play certain games like Rock band try this tip:
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  5. New screen will appear like
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
And after that wait till your game is loaded.
Click here to view full tip.
Nov 16, 2009 | Sony PlayStation 2 (PS2) Console
Rock band 2 for ps2 not working right
We had the same problem on a PS2 (thin) that is several years old. We tried exchanging the disk - same problem. We have a lot invested in the PS2 system and just bought several new games for it for Xmas so we decided to buy a new PS2 and see what happened. The Rock Band game works perfectly in the new PS2 with no issues.
Dec 28, 2008 | MTV Games Rock Band for PlayStation 2
CANT PLAY GAMES NEW PS2
good buddy,if your ps2 is pal then you can only play disc with the region 2 designation only,if you want your ps2 to play other region such as ntsc/uc U.S. or ntsc/j ***.you need to bring it to a certified techman for modding.thats the only way for you to dissolve this problem.
Dec 24, 2008 | Sony PlayStation 2 (PS2) Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
