Question about Pioneer Audio Players & Recorders
I have a Pioneer twin tray cd/cdg pd-v310g player and the top tray or tray 1 ejects halfway and then says no disc. It then pulls the tray back in and completely ejects tray 2. What are the possible problems and how can I fix it?
robotek
  • 1512 Answers
SOURCE: Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Posted on Jul 07, 2008
  • 85 Answers
SOURCE: Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Posted on Jan 08, 2009
  • 85 Answers
SOURCE: CD player does not play discs
Laser has died ,problem with pioneer is laser costs are ridiculous and write the machine off
AREA51S4B
  • 30 Answers
SOURCE: Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
Posted on Jul 27, 2009
gokomets
  • 120 Answers
SOURCE: my Pioneer PD-TM1 18 Disc player reads through all
Seen alot of these "drop" the laser lens inside the unit! Have had some luck glueing the lens back on using radio/tv cement. Don't try super glue or it will ruin the lens! No luck replace the laser!
Posted on Apr 13, 2010
I "stupidly" put two disc
I think your best option is to take the top off and see if you can straighten the pin.
If not then you may need to replace one or both of the trays.
Tray 1 Part No. PNW2709 around $30.00
Tray 2 Part No. PNW1840 around $12.50
Apr 21, 2011 | Pioneer PD-V10G 2-Disc CD Player
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
The pd-f1007 301 disc player was working fine yesterday, and this morning i turned it on,, and the display didn't come on, and the tray just keeps spinning very slowly, any ideas
You may need to take the backing off of the player to check if any cds might have jamed in the actual cd player. i have one similar to this that jams because of one cd that is a little bit larger then the other.
Jun 21, 2009 | Pioneer PD-F1007 301-Disc CD Changer
Jan 07, 2009 | Pioneer PD-F805 CD Player
Pioneer elite pd-f27 300+1 cd changer
I've owned two of these players, one currently, and both exhibit this behavior. Although frustrating, it seems to be inherent in the vertical loading mechanism. Every finicky CD I pull out of the PD-F27 plays perfectly in my single-loading tray player, including CD-Rs. One would expect more of an "Elite" product, but there you are.
Mar 17, 2008 | Audio Players & Recorders
Pioneer 301CD Player PD F1009 disc tray jammed
I had this same problem today on my pd-f1007
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Jan 01, 2008 | Pioneer PD-F1009 301-Disc CD Changer
Pioneer PDR-W839 Jammed Disc Changer (previously posted)
hello poopig1, after further review, I meant to describe this: look for a pinhole in the area of the CD tray to insert a pin...similar to the same pinhole you see on a PC's cd player to eject the tray manually. If there is none, then try this: Open the cover and find the motor that, when turning, performs the tray ejection. Then, turn that motor by hand until the entire tray (or cartridge) is ejected. Then power up and observe the events.
May 31, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
PD-F505
try a lens cleaning cd,if this doesnt work is more than likely optic (laser) faulty as laser has to focus first before spinning disc.if it cannot focus disc will not spin..
May 15, 2007 | Pioneer PD-F505 CD Player
98 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
