Question about Video Game Consoles & Games
I have a red quarter flashig - Video Game Consoles & Games
    Master:
  • 508 Answers
If you have a red light on a xbox 360 you need to refloe the CPU and gpu with a hot air gun. You'll need a torx screwdriver to take it apart and you can find all the stuff o repair it on eBay .
Posted on Apr 09, 2011
Fuel reset 89 festiva location
Check in glove box under seats or in both quarter panels behind the brace near the fuel neck go to rockauto.Com put in your vehicle info and then go to inertia switch to see what it looks like red top black bottom 2 wires?it should be in the quarters by taillights or glove box I tried to look up your owners manual but it only goes to 96 so look for the red top that's it
Nov 17, 2017 | 1989 Ford Festiva
Rear quarter windowndow
find the motor to the windo in queston ,follow the red wire to the switch.
May 27, 2013 | Jaguar 1994 XJS Convertible
HOW DO i CHANGE THE BATTERY IN A CENTER POINT RED DOT SCOPE
should be a shallow slot on the scope that looks like a quarter will fit to loosen cap. Just use a quarter and turn counter-clockwise.
Mar 17, 2013 | Centerpoint Technologies Centerpoint Red...
Hi my 5310c music expres ph was sweech off during the saftwer complat. but not after flashig its not sweech on what con i do plz help me sir!
ya, it is mobile software problem but i have solution try it. CONNECT CHARGER SWITCH ON BUTTON AFTER 5 MIN SWITCH ON PHONE.
May 03, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
Inspiron b110 wont turn on only green flashig
Unplug your computer, wait 30 minutes, plug it back in and try again.
If it still doesn't work, it's got a serious problem. If it isn't under warranty with DELL any longer, take it to a reputable repair facility.
Apr 14, 2010 | Dell Dimension™ B110 PC Desktop
I have a Panasonic TH-42PZ70BA Plasma TV. Went to switch it on & it cut off instantly with the power button flashig red. Tried unplugging and leaving but still the same
With the information given here it seems that there is a power supply issue and the TV needs service in the power section or power supply section of the TV.
There is a protection circuit that will not power the unit if there is a voltage overload in the primary section of the power on circuit. This is a warning that something in the circuit is not voltage or current correct and has halted operation.
You need a service tech to diagnose the issue.
Mar 13, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
95 ford explorer over drive light flashig shifting
you will not lose the codes they will come back, head to a transmission shop, there is a internal problem and the longer you drive it the more internal damage is being done.
Jul 15, 2009 | 1995 Ford Explorer
Quarter of red ring.. bottom right
i'm going thru this same problem right now...remove the harddrive then reboot the console...if it boots up properly then your hard drive is shot...that was what was wrong with mine..i bought a new hard drive and it work great again
Jul 14, 2009 | Microsoft Xbox 360 Console
Red light start up
i just answered this same question so heres some things NOT to do and check if you have done ANY of these things in the past:
1. Make sure the console sit in an open space with nothing blocking the air from coming in and out.
2. Be careful not to put the console next to a hot item such as stove, radiator etc.
3. From time to time check on it and make sure all the fans are working and that your console does not over heat, if it does you might want to buy some kind of a cooling system.
4. DO NOT put your console outside in the cold weather or in the freezer it might cause even bigger problems!
5. If you still have your warranty now it is a good time to exchange your console for a new one! Don?t wait like I did?
From my experience this should prevent the 2 red lights from coming back and from the appearing of the 3 red lights which means your console need to be repaired!
Oct 13, 2008 | Microsoft Xbox 360 Console
Flashig oil light
You either have a loose/worn engine bearing or a worn out oil pump, do not drive the car this way, you will cause serious damage to the whole engine. A oil switch is for a light, it turns on the light when oil pressure falls below about 10 PSI, a sending unit is for a guage that shows oil pressure with a scale, it may have numbers on the guage or just green and red, or high and low.
Oct 10, 2008 | 1992 Buick Roadmaster
Video Game Consoles & Games Logo
21 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
