Question about Dvtech Software
I received a phone call to make any appointment for a set top box and aerial to be installed. I wasn't home and my Father took the call and couldn't write down the return call number, and he was told you would ring back after lunch that day. When I had not heard for 2 days I rang Centrelink and they gave me your number. I hung on for 35 minutes with no success and decided to email you, but I am wondering if they have given me the right number, if so I would like to make an installation appointment, if not, would you please let me know that I am following the wrong lead.
  • 32,281 Answers
FixYA does not install aerials etc. FixYa is a help support site.
I'm afraid you have the wrong lead.
Posted on Apr 09, 2011
Testimonial: "thank you so much for you quick response it looks like it is back to the drawing board"
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Sky problem
Freeview has nothing to do with satellite. FreeSAT is the one that uses a satellite dish for reception. FreeVIEW is received through the aerial.
Also, don't fall for the "digital aerial" scam. I install aerials as part of my business. I've been to homes with aerials 20 years old, covered in soot from the chimney and they still pick up Freeview perfectly well. Equally, I've been to homes where the owner has bought some gold plated multi-finned "digital high gain" monstrosity that has awful reception characteristics.
If your TV aerial is okay, then just plug it in to your Freeview receiving TV and do the tuning.
If you do want Freesat then you will need a satellite dish along with a Freesat receiver.
Sep 04, 2014 | Televison & Video
Panasonic User Manual
as far as I am aware, you need a standard analogue aerial to receive Freeview, not a dish. The aerial plugs into set top box, which is connected to tv by scart. Freeview is different from Freesat
Nov 08, 2013 | Lands Phones
I have Sony BX400 40” LCD Projection TV. It shows ghost image while reception through set top box, however, does not while on DVD mode. What could be the problem / solution. I have changed my set top box,...
hello there could be a few things that could be wrong 1 check the male aerial connection make sure it's fixed tight . 2 you may be getting interference from other devices near your tv like a cordless phone 3 your aerial could have moved slightly try retuning it again also make sure the aerial connect to the set top box and the lead from the set top box to the tv hope it helps
regrads
shaun
Dec 27, 2010 | Sony Televison & Video
The humax keeps on messaging that the antane cable is short circuited. is this an internal problem or a problem with the aerial itsefl
The Humax PVR-150T will definitely have problems using an indoor set top aerial; this is true of almost all Freeview receivers. Freeview signals are typically hundreds of times weaker than terrestrial transmissions and if you've managed with a set top aerial so far it's been working more by luck than design. I find that most set top aerials are so badly made that they're often faulty when new, but as most tend to flogged cheaply at markets and car boot sales the supply chain has no incentive to improve the product.
There has recently been a national Freeview retune, to complete this correctly your box needs the kind of solid and reliable signal which you cannot get with a set top aerial. Some receivers had compatibility issues with the retune and in many cases manufacturers broadcast OAD's (Over Air Downloads) to update the firmware in the boxes to be compatible. OAD's almost never successfully install via set top aerials.
There is an official list of Freeview devices which are known to have problems with the retune; unfortunately it has not proven to be a comprehensive list. The Humax MG-TU1 is one of those which have had problems and from memory it's closely related to your Humax PVR. The official advice is that you contact Humax directly on 0870 247 8800, but they'll probably instruct you to test your box using the aerial system it's designed to use before they'll be interested in offering further assistance.
Nov 05, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
My analogue tv doesn't do anything when connected to the new set top box. The scart is connected and the aerial also. Are there some anologue tv's that can't receive the digital signal? I already have 1...
Have you checked that your aerial is connected into the set top box & not into the TV? The aerial signal has to go into the set top box & then the box will be connected via your Scart cable into the TV. On the TV you will need to select the Scart input ie. AV1. This should give you the set top box incoming signal, you might then have to tune in the box by following the on screen instructions. Hope this help.
Nov 02, 2009 | Televison & Video
On the LG KP500 can you get a text alert of an appointment?
Set your appointment through your calendar. It will indicate when you wished to be notified and how long you want to be notified. If your worried about the sound of the alert when you receive your appointment notification, then change the default sound within your settings.
Mar 13, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
Manual left behind in Afghanistan
make sure yo have the leads connected correctly,after you connected an aerial lead from the box to the tv aerial input,make sure the box is switched on then tune the tv until you see a signal from the box (usually 35)if you do it through a video you may find its on the same frequency causing ghosting on the picture,in which case you will have to change the output frequency of the box or thee video
Feb 06, 2008 | Audio Players & Recorders
Computers & Internet Logo
96 people viewed this question
Top Dvtech Computers & Internet Experts
David Payne
David Payne
Are you a Dvtech Computer and Internet Expert? Answer questions, earn points and help others
