Question about Broderbund The Print Shop 22 Deluxe Full Version for PC
I have a new computer with 'Windows 7' installed. I would like to run 'Print Shop Deluxe 22' Is there a patch to make the program work? I need a simple fix. Hope someone can help me. Cheers.
  • Broderbund Master
  • 11,800 Answers
There is no patch, you will either have to purchase the upgrade to 23.1 or you will have to install XP Mode (directly from Microsoft) and in it to install your program.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Posted on Apr 09, 2011
    Scholar:
  • 77 Answers
You can use the Windows Vista Compatibility patch which works equally with Windows 7.
You can download it here.
When the download is complete, close the Download window. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update. Then follow the onscreen instructions to complete the installation.
After the patch being installed, you can
launch and use The PrintShop® 22.
Hope this helps!
I HAVE WINDOWS VISTA AND IT DOES NOT INSTAL ON MY COMPUTER
Print Shop 22 is not compatible with Vista (or Windows 7): this is the official Microsoft position.
https://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?type=Software&s=The%20Print%20Shop%2022%20Pro%20Publisher%20Deluxe
Basically, you need to get a 'free' upgrade if you bought the product as the program will also not work in 'Windows XP' compatibility mode.
If you are technically inclined, you could install a 'Virtual Machine' (such as the free Oracle VirtualBox) and install Windows XP under it: this should permit you run PS22 in the virtual machine.
Hope it helps.
Sep 21, 2011 | Broderbund The Print Shop 22 Deluxe Full...
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
I have the full version of print shop deluxe22 and it won't let me install it on my hp laptop HP G71-442nr Notebook, Running windows 7
Print Shop 22 Deluxe is not compatible with Win 7 (x86 or x64bit) Operating.
You have to use the Print Shop 22 Deluxe version 23.1 - compatible with Win 7 & Vista.
Hope it helps.
May 25, 2011 | Broderbund The Print Shop 22 Deluxe Full...
I installed printshop 2.0 deluxe on my new computer running windows 7 and I can't get the program to load up. What can I do?
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 24, 2010 | Broderbund The Print Shop Deluxe Version...
I tried to install Printshop deluxe 22 on my new computer which has windows 7.it says that there is an error.what would you suggest
I suggest that you tell us EXACTLY what the error-message stated.
Or, start the Windows Program Compability Wizard, and tell Windows 7 that you want to install a Windows XP program.
Then, install the software.
Aug 22, 2010 | Broderbund The Print Shop 22 Deluxe Full...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Just got a new windows 7 and wanted to use my Print Shop 22 Deluxe but says certain parts are not compatible. What do I do?
just got a new computer with windows 7 and wanted to use my Print Shop 22 deluxe but says certain parts are not compatible , What do I do ?
May 20, 2010 | Broderbund The Print Shop 22 Deluxe Full...
Can't run Print Shop Deluxe version 23
You will need Microsoft .NET Framework to run some instances of Print Shop Deluxe. If you install it, the patch will not work without .NET Framework installed.
Feb 05, 2009 | Computers & Internet
I am fairly new to PCs. I recently purchased a Toshiba 205 and have Vista SP1.  I purchase Print Shop Delux 22 and started the installation process before I read the statement about don't start...
Hello, Encore Software has released a patch to make Print Shop Deluxe 22 compatible on Windows Vista.
Here is what they say here:
http://support.encoreusa.com/kb.asp?id=571
Problem I am looking for the Vista compatibility patch. Solution This Windows® Vista update will detect and repair The Print Shop® 22 and PrintMaster® 17 applications already installed on your computer. After applying this update The Print Shop® 22 and PrintMaster® 17 will operate normally on computers running Windows® Vista.
Update Instructions
1. Click the link located at the bottom of this page.
Note: For Microsoft® Internet Explorer® the File download dialog may appear. Select Save this program to disk and click OK.
2. Choose a location (e.g., the Desktop) and click Save. The download process will begin.
3. When the download is complete, close the Download window.
4. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update.
5. Follow the onscreen instructions to complete the installation.
Note: Depending on system or user account settings, you may encounter several interruptions during the installation process. If so, please click Continue or Allow in order to proceed.
6. Launch and use The PrintShop® 22 or PrintMaster® 17.
Click here to download Broderbund_Print_Update.exe (26.7 MB)
Aug 21, 2008 | Computers & Internet
Broderbund The Print Shop 22 Deluxe Full Version for PC  Logo
151 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
