Question about Facebook Social Network
Cannot rebember my pass word - Facebook Social Network
  • 68 Answers
Go to https://www.facebook.com/recover.php and follow the instructions to recover your password.
Posted on Apr 09, 2011
I can not sign in
INSTALL VERSION 10.0.....,THERE ARE PROBLEMS WITH YAHOO MESS 11.
Jul 14, 2013 | Yahoo Messenger
Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw] Receiving response... [FAILED] *** ...
sometimes YM is very busy for connecting people..that is why you are unable to connect but try reconnecting again...it works
be sure your password and username is correct and your internet connection is stable...
Jun 27, 2011 | Yahoo Messenger
I cannot rebember my pass word have tried all suggestions
have you tried forgot password? is you email account still active because you will have to open the email to get the password.
Apr 09, 2011 | Facebook Social Network
Cant sign into yahoo messenger. Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw]...
[VIP Raw] Receiving response... [PASSED]
[VIP Raw] Checking HTTP response code... [PASSED]
[VIP Raw] Parsing connection server IP address... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [PASSED]
[VIP Raw] PASSED *** 98.136.48.85 ***
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [PASSED]
[CS Raw] Sending port check command... [PASSED]
[CS Raw] PASSED
Checking login servers...
[Login] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0001' ***
Aug 10, 2010 | Yahoo Messenger
I'm looking for torque specs on the water pump bolts to the block for 2000 chevy blazer 4.3 L
Fig. Exploded view of the water pump assembly mounting-4.3L engine
To install:
  1. Clean the gasket mounting surfaces.
    NOTE The water pumps on some of the engines covered may have been installed using sealer only, no gasket, at the factory. If a gasket is supplied with the replacement part, it should be used. Otherwise, a 1 / 8 in. (3mm) bead of RTV sealer should be used around the sealing surface of the pump.
  2. Apply sealant to the water pump retainer threads.
  3. Install or connect the following:
    Water pump using a new gasket. Tighten the water pump retainers to 89 inch lbs. (10 Nm) for 4.2L engines, or to 30 ft. lbs. (41 Nm) for 4.3L engines. For 5.3L engines, tighten the bolts to 11 ft. lbs. (15 Nm), then to 22 ft. lbs. (30 Nm). Coolant hose(s) Water pump pulley. Tighten the pulley bolts to 18 ft. lbs. (25 Nm). Fan or fan and clutch assembly Serpentine drive belt (if equipped) by positioning the belt over the pulleys and carefully allow the tensioner back into contact with the belt. V-belts (if equipped) and adjust the tension Upper fan shroud Negative battery cable
  4. Refill the engine cooling system.
  5. Run the engine and check for leaks.
Hope this help to solve it; rebember rated this post. Good luck.
May 01, 2010 | 2000 Chevrolet Blazer
I'm trying to restore my Toshiba Satellite...
Try to format it using an external cd-rom if you have one or using an external harddrive.
Jul 03, 2009 | Toshiba Satellite L25-S119 Notebook
Facebook Social Network Logo
19 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
