Question about Home
My chi nano plug fell in the water! Now the test button won't stay pressed and I can't reset it! It's been a couple of months and it still won't work! What do I do?
5 Suggested Answers
SOURCE: haier window air conditioner
I suggest you check the ground of the wall socket. Many three proung sockets are not grounded.
Posted on Mar 31, 2008
  • 289 Answers
SOURCE: my ipod nano fell in a pond and it took me 8 min to get it out.
well, since its a nano and they don't actually turn off, it actually shorted out as soon as it fell in the pond, so its done for... i'd throw it in the trash can...
Posted on Oct 06, 2009
  • 1033 Answers
SOURCE: Water got into the plug.
Hello, most likly you will have to replace the whole cord assembly, here is a link to parts for you AC http://www.appliancefactoryparts.com/airconditioners/goldstar/m1003r.html
Posted on Jun 08, 2011
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: My on off button won't stay pressed down so the vacuum won't stay running.
    Hi Melissa,
    I'm sorry to hear you're having difficulties with your DC17. If the on/off switch doesn't seem to be working correctly, it's best if you get in touch with us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Nov 14, 2011
    Error code e01
    do the following steps: God bless you
    To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
    To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
    POWER SCRUB PLUS = Heater fault
    REGULAR WASH = Water filling fault (over or under filling)
    RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
    To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
    If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
    If more than one fault occurs, more than one light will be lit.
    Jul 21, 2012 | Dishwashers
    Water won't drain
    Do the diagnostic test:
    SHU 53 MODELS
    To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
    To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
    To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
    0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
    1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
    If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
    The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
    .You can get required parts from www.repairclinic.com
    Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
    My ipod nano fell in a pond and it took me 8 min to get it out.
    Oct 06, 2009 | Apple iPod nano MP3 Player
    I charged my 4gb nano 3rd gen ipod, but it won,t
    slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
    Sep 10, 2009 | Apple iPod nano
    The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
    SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
    Aug 01, 2009 | Bosch SHU5315UC Dishwasher
    Ipod Nano doesnt turn on AT ALL
    plug it to your computer, load up itunes, if your ipod owners link comes up, find your factory reset button, you won't lose any music or info, it will just reset itself to the settings when you first bought, i had the same problem.
    Jan 13, 2009 | Apple iPod nano
    8 GB Ipod Nano went dead and now won't charge
    does it work on the charger? if not, then contact apple or your dealer for more assistance or repairs.
    If it works on the charger, plays music and so on, your battery is probably dead and you need a new one.
    Mar 24, 2008 | Apple iPod nano
    Ipod nano won't work for us
    try pressing the reset button with a toothpick on the nano if this doesnt work then read the manual on how to do a hard reset.
    good luck.
    smeags.
    Dec 31, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
    Home Logo
    20 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
