Question about Philips Magnavox 51MP392H Rear Projection Television
Need to replace the glare screen cover where can i get another one
  • Philips Master
  • 5,138 Answers
Call Local TV Shops or Look on EBay under Electronics/ TV Parts
Posted on Apr 09, 2011
SOURCE:
S.N RS051DL103300. I just want to know if you sell a protective screen that is anti glare?
Anon. Protective screen that is anti glare, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
NuShield Anti glare Films In TV Room Design
FAQ Answers for Questions on our TV Screen Protectors
TV Screen Covers ScreenProtek
How to rid your HDTV of reflections
May 26, 2016 | Televison & Video
Need to replace a cracked screen, where can i find one or have one made?
If JVC does not have it you are likely out of luck, if the outer protective screen it might be possible to have a piece of plexiglass cut and put in but the original was anti glare coated so you would likely have a glare issue.
Dec 14, 2012 | JVC HD-52G886 52" Rear Projection HDTV
Glare from laptop
LOL, not much you can do about the glare unless you buy some type of cover that goes over the screen.
Have you tried darkening the screen by using your keyboard keys that controls the brightness and darkness? Usually they work in conjunction with the FN function key.
Apr 18, 2012 | Computers & Internet
I want to reduce the amount of glare on my screen but i cannot and im struggling with the glare
Buy a anti-glare privacy screen. (Privacy monitor filter)
It's the best way. They should be available at any computer store.
It is thin like a plastic cover that you place on your screen.
Sep 17, 2010 | Compaq Evo N620c Notebook
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Shows alot of glare
You can get screens from newegg.com, amazon.com and other sites that cover you tv screen to mellow the glare
Sep 03, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Screen reflection and glare
you can buy a protective anti-glare screen that covers the tv screen
Jul 09, 2009 | Televison & Video
Glare is too much for my eyes, need a glare guard.
You can purchase a glare guard from 3m, available from cdw, tigerdirect, dell, 3m etc.
The price ranges from around $53 to $90 but you might find cheaper.
This is one model but there are several
3M™ EF200LB Anti-Glare/Radiation Computer Filter, Black Frame
May 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Cracked cover D52W19
i have used plexiglass for customers in the past. it has work just fine. rca call this thing supersheild and charges about 200 dollars.
Jan 12, 2008 | RCA D52W19 52" Rear Projection Television
57S715 Hitachi HD RPTV protective screen removal & cleaning help.
Research at www.HitachiServiceUSA.com ...........
Generally, front speaker grill cover comes off , then
screen frame assy. off , then take apart, remove protect
glare screen. Reassemble ( keep same order - position )....T.
Please rate solution to problem........
Aug 21, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Philips Magnavox 51MP392H Rear Projection Television Logo
236 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
