Question about Dell TrueMobile 1184 Wireless Broadband Router (802.11b) 9U555 (9U555)
I can not remotely connect to my other computer at my business since I hooked up the router to it. It has no problem connecting to the internet. What is wrong? Is there something that I must configure in the router? Something is blocking me from remote access. Can you tell me the proceedure to correct this problem. Thanks
  • Louis Lofrese Apr 11, 2011
    Your comment gave me the solution to the problem. It is fixed. Thankyou very much!
  • Louis Lofrese Apr 12, 2011
    thanks for your help.
  • 977 Answers
Hi!
Yes, the router is blocking the connection. You have to forward the specific port (Port Forwarding) to your remote computer to enable it! I'd like to help you but I have to know which program are you using for the remote controlling, in order to figure out the port you need to forward...
Waiting for your reply...
Regards,
Pelu.
PS: It's the middle of the night here, so my next response might delay a few hours... Thanks for understanding.
Posted on Apr 09, 2011
  • Ran Kedar
    Ran Kedar Apr 12, 2011
    Glad to hear that! :)
My router is not detecting an internet connection when hooked up to my cable modem. However, when my modem is hooked directly to the computer there is an internet connection
Try power cycling the router.
Disconnect the router from all computers and devices.
Power off the router. Power on the router. Reconnect the router to all computers and devices. Check the Internet connectivity.
Mar 01, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
My HP DeskJet 722C printer is directly connected to my main computer,not USB. incoming cable is to my modem, then to my linksys wrt54gs wireless router, then to my main house computer. i have connected a...
From your description, you appeared to have to have set up the printer correctly to print over your internet.
Can you see the remote computer from the main computer and the remote computer from the main computer?
Are both computers in the same workgroup or network name?
You may want to check your installation against my instruction on setting up a shared printer.
Please click on this link and follow my instruction on setting up a shared printer in a network :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Nov 23, 2010 | Linksys Wireless-G WRT54GS Router...
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
We are on Starband Satellite internet. Have windows programs , both vista and xp. We have the linksys G wireless internet system. How do we install it ?? So far, when we put it in, nothing works. No...
Yes you can but it is not as easy as using a router with a cable or dsl connection.
The 360 modem requires the Mission Control software in order to run properly so you can't just hook it straight to a router.
What you need to do is use an old computer to sit in the corner and act as a router(kind of) and then connect it to a real router.
When your finished you won't even need a monitor for it. You will need either two network cards in it or 1 network card and a usb port to hook it up to the 360 modem. Make sure network cards are also working correctly. Install the starband mission control software and make sure it is working correctly.
In Winxp go to network connections and right click on the one hooked to the starband modem and click properties. Now click on the advanced tab and check "Allow other network users to connect through this computers Internet connection.
You can plug the other network cable straight into a switch and this computer will hand out ip addresses through ICS(Internet connection sharing) built into winxp.
You can also get a wireless router and change the ip address of it to match the range that ics is handing out and disable the dhcp server so that you don't have two things handing out ip addresses.
If you use the web accelerator you will have to put it in the browser of each computer that you will be using (in the browser under proxy). It will be something like 192.168.0.1:9877.
Also make sure your running a firewall on your little router-computer. If the computer is running winxp professional you can take the monitor off and use remote desktop connection to check on things or to control it. Or search the Internet for VNC.
from____cajun101...yahoo
hope this helps you get more confused :)
Oct 24, 2009 | Linksys Wireless-G Broadband Router
I checked my firewall. All cords are connected properly. The same
When using a router with your internet connection (cable, dsl modem etc.) hooked directly to the routers data port it will use the roughter's dhcp to assign ip addresses to other computer on the network. If you have your internet connection hooked directly to a computer and are using internet connect sharing then you must disable the dhcp service on the roughter because the internet connect sharing has its own dhcp and it will assign all the ip addresses. to get into the roughter's setup you open a browser (internet explorer, mozilla etc.) and type 192.168.1.1
Aug 22, 2009 | Linksys Wireless-G Broadband Router
I hooked up wireless internet and my main coputers internet isnt
check the connection or from where u r connected the wireless connect just see that the problem will be solved ok
Aug 22, 2009 | 2wire 2700HG-B Router (2700HGB)
Security First SDVS-1904 Setup (Not D-Link) Needing help with this. We installed the 4 cameras and the DVR. They're working fine. Now I'm trying to get it to come up on the computer so we can see the...
I'm not sure if you are still looking for the answer, but I think the problem may be that you need to enter the PUBLIC IP address of the modem at the remote end instead of the PRIVATE (ie. 192.168.1.x) IP that was actually assigned to the DVR. It works best if you assign a static IP to the DVR on the remote end and enter that IP into the router's DMZ. You might also want to get a free account at dyndns.net and setup a FQDN for your business router/modem. That way you can connect to it using something like "mybusiness.homeip.net" instead of an IP address, and if the IP changes it will still find it. You will also have to configure your modem at the business to automatically update the dyndns server when the IP changes.
Mar 04, 2009 | D-Link Securicam Network DCS-950G Wireless...
Router problem
Hi .
First who is your service provider?
Can you connect to the internet if you directly hook your modem to your computer.
1>If so connect your Modem to your router on the colour code slot on the router which says modem
2>Connect a cable from the router to your computer
3>The lan light on the router should be turned on
4>Check wether your lan says connected . To check that click start-> control pannel -> network connections
5>If it says connected try internet explorer settings
6>If it says limited or no connectivity
Click start ->run -> cmd->ipconfig
7>It should say ip address as : 169.254.x.x.
8>If so type ipconfig/release
9>It shoul say ip address: 0.0.0.0
10>Type ipconfig/renew on command promt
12>Disable and enable lan
Let me know if this helped and also if you dont what kind of messages you get .
Mar 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I can connect to the internet with cable connection to Belkin Modem with wireless G router but when I unplug and try to connect with wireless G network adapter no joy, get an error message 797 no reply...
Go into control panel-intenet options-connections-lan settings-make sure the only box selected is the top one for automatically detect settings.and make sure you have connected with the wep key that came with your wireless router.
May 12, 2008 | Computers & Internet
Dynex ESW5 connecting PC and Mac
after hooking it up only one computer has internet
Apr 13, 2008 | Dynex 5 Port 10/100 Ethernet Switch...
Dell TrueMobile 1184 Wireless Broadband Router (802.11b) 9U555 (9U555) Logo
139 people viewed this question
Alun Cox
