I can't fine the installation manual online for a A. O. Smith multi horsepower condenser fan motor..The motor did not come with a installation guide in the box. It is suppose to be a FSE6000 according to the catalog I used to order it. on the motor is 48N69A01 I don't know what wires to connect. I want the 1/5 hp setting.
  • 413 Answers
If you will post all the colors, someone could more easier tell you
Posted on Apr 09, 2011
Just had AC tech charge $257 to replace capacitor on carrier 38ckco48300. tech also stated condenser fan motor may have been damaged with replacement cost of $500. can a condenser fan motor for this unit...
I don't know what part of the country you are in, but here in Okla. a condenser motor can be bought by the home owner for around $100. You should be able to go to any appliance supply house and purchase your own motor. Take the model and serial number with you, it may help. If you have a local carrier distributor, they should give you a users manual. Try your best to get a motor close the the same as what you have. Note the horsepower, rpm, voltage and take the fan blade with you in case you need a new one. Hope this helps. Mark
Sep 07, 2011 | Heating & Cooling
We have a failed condenser fan motor which was a 1/12 horsepower 1300 RPM - 115v We got a blower motor replacement from our vendor which was a 1/20 horsepower 1500RPM - 115v The motor is tripping out on...
Motor usually trips out as it is overloaded. Check the rated amp draw on the replacement motor verses the OEM motor. OEM motors usually are built a little different to meet certain conditions in their design. You may need to get one. Also, make sure your condenser is very clean so as to not cause overloading the motor. Could have been the reason for the first one to fail.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I am installing the timer for a whole house fan. I hooked red up to load, black to hot and white to neutral per instructions...confirmed with meter....the timer does not seem to work..I can turn on and...
A) GE 15069 image at Amazon
http://www.amazon.com/60-minute-Automatic-Shut-Off-Timer-Switch/dp/B002DNAE7Q
15069 manual
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/In-Wall-15069-Manual-eng.pdf
Manual shows GE 15069 countdown timer is rated up to 1/2 horsepower
Whole house fan is likely 3/4 horsepower >> check nameplate on fan motor.
B) work around:
Hook timer up to a contactor/relay.
Timer turns on 120 volt, 7 watt contactor coil.
Contactor turns on fan motor
http://waterheatertimer.org/H230A.html
Square D contactor at Grainger
http://www.grainger.com/Grainger/SQUARE-D-Compact-Contactor-5B132?Pid=search
http://www.pexsupply.com/Furnas-Controls-45EG20AF-2-Pole-30-Amp-120V-Contactor
I buy these contactors at local HVAC supply for $15
add a comment if you need help wiring this device.
C) List below shows countdown timers with horsepower rating:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Lutron MA-T51 countdown timer specifically says it cannot be used for motors, which says the electronics inside each device is Load specific
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
Dec 12, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
Oct 21, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
