Question about Alpine iXA-W404
My speakers started pushing out less power in my front left and back right speaker what should I do?
  • 30 Answers
Check the fader on the stereo and balance them.
Posted on Apr 10, 2011
I need information on what wires use fuses on a sony cdx-4000
You may find your Sony unit has the fuse built-in to the back of the player - hence, modern units no longer require an in-line fuse in the wiring.
yellow = 12v constant or battery power
red = 12v switched or ignition power
black = 12v ground or chassis ground
blue = power antenna turn on
blue/white = amplifier turn on
white = left front speaker +
white/black left front speaker -
gery = right front speaker +
grey/black= right front speaker -
green= left rear speaker +
green/black left rear speaker -
purple = right rear speaker +
purple/black= right rear speaker -
lt blue= cell phone mute input
Hope this helps...
Nov 01, 2011 | Sony CDX-4000X CD Player
What is the color codes to a pioneer dxt-2266ub? putting it into a 1997 firebird.
PIONEER STEREO DXT-2266UB
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Owners Manual = http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DXT-2266UB_OwnersManual0607.pdf
1997 PONTIAC FIREBIRD WIRE COLORS
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Hope this info helps
please let me know if you need any further info
May 20, 2011 | Pioneer Car Audio & Video
The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14
1 ... .. ... 13
The pinouts are:
1 Mic in/center
2 Ground
3 Mic power/Bass
4 Audio power
5 Right line out/Speaker out Right
6 Right line out/Speaker out Right
7 Reserved
8 Key
9 Left line out/Speaker out Left
10 Left line out/Speaker out Left
11 Right line in/Rear speaker Right
12 Right line in/Rear speaker Right
13 Left line in/Rear speaker Left
14 Left line in/Rear speaker Left
Aug 27, 2009 | Biostar P4M800-M7A Motherboard
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
How to install kenwood kdc-x493 with kac-8104d in 1996 honda civic?
very simple on the back of the deck you will have a wire harness
Yellow = constant power supply
Red = Switch power supply
Black = Ground
White = left front speaker +
White /Black stripe = Left Front speaker -
Grey = right front speaker +
Grey /Black Stripe = right front speaker -
Green = left rear speaker +
Green w/ black stripe = left rear speaker -
Purple = right rear speaker +
purple w/ black stripe = right rear speaker -
wires for the honda are,
Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Left Front (+) Blue Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Jul 25, 2009 | Kenwood KDC-X492 Car CD/ MP3 Player
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
Help on ajusting the speakers
If you have the factory stereo, push in the power button with the stereo on, and then turn it to adjust the balance between left and right. Then you can return it to the normal position. Then PULL out the same knob and when you turn it you will adjust the "fade" between front and rear speakers.
Mar 27, 2009 | 1991 Volvo 740
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Feb 26, 2009 | Kenwood Car Audio & Video
Wires came out of the plug
From Pioneer Electronics Support Website Yellow - To terminal always supplied with power regardless of ignition switch position. Red - To electric terminal controlled by ignition switch (12 V DC) ON/OFF. Black (ground) - To vehicle (metal) body Blue/white - To system control terminal of the power amp or Auto-antenna relay control terminal White - front speaker left + (positive) White/black - front speaker left - (negative) Grey - front speaker right + (positive) Grey/Black - front speaker right - (negative) Green - rear speaker left + (positive) Green/Black - rear speaker left - (negative) Violet - rear speaker right + (positive) Violet/black - rear speaker right - (negative) Best of Luck.
Sep 09, 2007 | Pioneer DEH-P3800MP CD Player
Alpine iXA-W404 Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
