Question about PfaFF Tiptronic 2040
All was well when I sat down but after about twenty minutes the thread started to break. I now can't sew three stitches without it breaking and then freezing up. I oiled it and replaced the needle but that didn't help.
    Scholar:
  • 89 Answers
First check to make sure the thread is in the takeup lever (the part that goes up and down when you turn the hand wheel).
If it is threaded correctly then it could be just about anything, probly going to need to take it to a pfaff teck.
Be carefull who you take it to, lots of shops say they have a trained teck but very few realy do.
Posted on Apr 09, 2011
I have a janome 6600. The stitches started jamming up and breaking.What might be causing the challenge with the stitches?
Difficult to say without really seeing what's happening and which thread is breaking. If the top thread is breaking, check to make sure the thread is not wrapped around the spool pin or a thread guide.
Just some things to try:
Install a brand new needle.
Be sure to clean and remove all the thread pieces, lint, etc from under the needle plate, around the shuttle, etc. Oil as instructed in the owner's manual.
Remove all the thread from the machine. ALWAYS RAISE the presser foot when threading the top and rethread the machine from the beginning. Check that the thread path is correct and the bobbin is loaded and threaded correctly.
Be sure to use good quality thread--no Old or bargain bin threads!
Solve Most Sewing Machine Problems With These Simple Tips
Why Does My Sewing Machine Keep Jamming Sewing Made Simple
Feb 11, 2018 | Janome Sewing Machines
Blind stitch won't lock
This is hard to find in the internet so I hope this will solve your problem...
Frequently Asked Questions
Q) Help!
I am breaking a lot of needles and the tension is getting too tight on its own while stitching and causing the thread to break. I am learning the machine for two weeks. Is it so sensitive too wools, cottons, and fleece that this would make such a major difference in the stitching - breaking needles, breaking thread?
(A) It may not be tension that is causing the problem with your portable blindstitch. If you have broken needles it has probably left some needle burrs in the thread and needle path that need polishing off with fine emory cloth (crocus) before sewing again.
Start with a new LWx6T needle without thread or fabric. Watch the needle as you turn the hand wheel. If there is needle deflection, reduce the penetration dial until there is no needle movement. If there is needle deflection caused by burrs, they must be polished off. Check the looper tip and two arms for any needle burrs and polish off. If there is needle deflection caused by the needle track lifting the needle, lower the track very slightly with the screws on the side of the black metal bracket above the needle.
Finally, Back off on the tension dial and retighten while you are sewing with a light strong thread and light to medium weight fabric, until you get the correct tension without loops. If tension is too tight it will push the thread up so it is not all the way down between the tension discs where it belongs.
(Q) I can't understand how to finish off at the end. It
always unravels. I have read the manual and it seems simple but I
apparently just "don't get it." Any help would be appreciated.
(A) At the end of the blindhem seam, position the needle all the way to the left, then use the knee lift to remove the fabric and jerk on the fabric at the same time. That will tie off the tread and break the thread at the
needle without bending the needle. You can weave the thread tail back into the stitches or cut it off. Before the above procedure, you could also turn the handwheel counterclockwise for a few stitches, then come back to the end of the seam and repeat the first procedure above.
Nov 15, 2007 | Tacsew T500
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Nov 17, 2011 | Sewing Machines
Thread keeps breaking
try to reduce needle thread tension. if no improvement then remove and look closely for any sharp point in bobbin case holder mechanism that may be breaking thread.
Nov 25, 2009 | White Sewing Sewing Machines
I am unable to get the machine to work. The thread breaks all the
When you re thread, make sure you take out your straight needle threads. completely then re thread the entire machine again. If this does not work. Thread your machine turn all tensions to 0 and pull your threads through at the needle point. slowly.
Nov 23, 2008 | White Sewing Speedylock 1600 Mechanical...
Brother Embroidery machine thread keeps breaking
It doesn't matter so much the thickness of the stabilizer but more a matter of it being taut like a drum and the proper stabilizer for the fabric you're using. Couple of reasons the thread breaks...the thread gets caught on the edge of the spool in the crack where the thread originally starts, you're not using the right size spool cap or the upper thread is wrapping around the spool pin. When I use my 170 for embroidering I always use the vertical spool pin to eliminate this problem. Try it and let me know how you make out.
Nov 18, 2008 | Bernina Artista 180
Sewing Machines Logo
57 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
