Question about Walter Drake Old Fashion Popcorn Maker
Stirring rod in stir crazy popcorn popper problem
I have a 8 qt. West Bend Stir Crazy Corn Popper that is about 6 mos. old. Tonight after using it 3 times consecutively, the stirring rod stopped turning. I took it apart and there are no kernels stuck. Any ideas what the problem might be or how I can fix it? I am presently overseas so getting a replacement isn't an option. Any help would be greatly appreciated as this is something our family enjoys immensely! Thanks so much, Natalie
  • Samuel Charles Spriggs May 11, 2010
    Natalie,
    When you say you took it apart, did that allow you to determine if the rod has just come loose? If it's not loose the motor is probably fried.
3 Suggested Answers
Lady Spark
  • 51 Answers
SOURCE: how much oil & pop corn oil do I in a Stir Crazy corn popper
2 tablespoons oil to 1/2 cup corn
Posted on Feb 05, 2010
  • 65 Answers
http://westbend.com/support/user-manuals/popcorn-poppers.html
Posted on Jun 10, 2014
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
The stirring rod fell off. How do I fix this?
The center hub is screwed on. With the popper cold, try unscrewing the center piece. The stir wire sits in a channel under the center piece.
Sep 02, 2013 | West Bend 82306 Stir Crazy® Popcorn...
What size is the popper 6 or 8 qts
The West Bend 82306 Stir Crazy® Popcorn Maker ca be either 6 or 8 qts.
The 6-qt model has a rounded domed shape as per the picture above; the 8-qt model has a straight-sided top.
The User Manual can be found here:
http://www.westbend.com/supportdata/L5557B_StirCrazyPopper_ALL.pdf
Jan 31, 2011 | West Bend 82306 Stir Crazy® Popcorn...
The manual got missed placed can you tell me the amount of kernnels to use in it. It is a six qt. stir crazy popper
USING YOUR STIR CRAZY® CORN POPPER
Place popper base on flat, dry surface. The heat-resistant base allows for safe table use.
Preparing Popcorn
There are two models of the Stir Crazy® Corn Popper, one for making up to 6-quarts and the second for making up to 8-quarts of popcorn. Listed below are the proper amounts of oil, corn and butter (or margarine) to use for making various amounts of popcorn. Do not attempt to make 8 quarts of popcorn in the 6-quart model.
Quarts of Popcorn
Amount of Oil
Amount of Corn
Amount of Butter
1 Tablespoon
⅓ Cup
1 Tablespoon
2 Tablespoons
⅔ Cup
2 Tablespoons
6
3 Tablespoons
1 Cup
3 Tablespoons
**8
3 Tablespoons
1¼ Cups
3 Tablespoons
Here is the link to download the manual: http://www.focuselectrics.com/supportdata/L5557B_StirCrazyPopper_ALL.pdf
Oct 16, 2009 | West Bend 82306 Stir Crazy® Popcorn...
6 cup stir crazy popcorn popper lid
There are lids around your house that will fit this. Try a butter or sour cream lid.
Nov 16, 2008 | West Bend 82306 Stir Crazy® Popcorn...
Brown oily leak
The oil is leaking around the stirring-arm-motor shaft -- it needs a new seal. It's not the oil you're using.
Nov 15, 2008 | West Bend 82308 Stir Crazy® Popcorn...
Walter Drake Old Fashion Popcorn Maker Logo
234 people viewed this question
Top Walter Drake Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Walter Drake Kitchen Appliances - Other Expert? Answer questions, earn points and help others
