Question about Sony Televison & Video
I have a sony kv-36fv310 and it blinks twice i would like to know what the code is and is it a easy fix thank you
    President:
  • 1,654 Answers
Which light is blinking the power indicator or the standby light one red the other is green, this will help me find the cause. But don't be shocked if is not what you want to hear.
Posted on Apr 09, 2011
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
What do sony wega blink codes mean?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 11, 2014 | Sony FD Trinitron WEGA KV-36HS420 36" TV
KV-32FQ70U led blinking twice
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
May 06, 2014 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
CRT sony tv
Likely to be Capacitors in the power supply, Getting Baggy or maybe have blown tops or check bottom burst as well, upgrade with higher voltage if possible
Jan 16, 2014 | Televison & Video
Sony wega kv-32FQ86B flashing light
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking light on Sony Tv
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. To get more details, http://electronicshelponline.blogspot.com/
Nov 21, 2013 | Sony KV-36XBR400 36" TV
I have a sony bravia and its not turnin on the red light its blinkin twice
2 Red Blinking lights on this model indicate an Over Current Protection status. This could be caused by a faulty power supply inside the TV or possibly by the Flyback Transformer.
This is repairable, but needs to be serviced by a TV service technician.
-Ben
Sep 13, 2011 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Hello, I have a Sony FD Trinitron WEGA #KV-36FV310 manufactured around 03'-04', all of a sudden lately i've noticed a ghosting blue line spiraling up the screen,i only notice it when the screen gets dark,...
It's the return of the line, it should be cut off completely. To make it invisible again the cutoff point for the blue cannon should be adjusted (practically this means - turn a potentiometer) - all it takes is a screwdriver and the necessary knowledge. How much it will cost - that depends on how expensive your repairmen are
Dec 04, 2009 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Sony blinking standby light
Hi shelly i have a lot of sonys come into my tv shop. There is a code for blinling problems but it never helps me.But blinking problems two blinks is says power supply problem i usually charge around 120.00 to fix this kind if you would bring it in.
It is very common problem and most service centers can fix this
Thanks Doctor video
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Is my tv dead?
no not at all , may be lot or h.o. transitror ar circuit dry solder, if any problem led red indicator blinks continuesly.. please chek all h.o section...and smps...
Sep 28, 2007 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Televison & Video Logo
94 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
