HP F4488 printer is keep on taking paper and stuck. If press power button, the stuck paper will come out. Also I tried to put new cartridges, even the problem is same
SOURCE: hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Posted on Dec 13, 2007
squipps
  • 204 Answers
SOURCE: HP PSC 1510
Usually in the instruction book or under "help" when you open your Printer under Control panel /Printer Properties there is a section that deal in flashing lights on the printer.
This will help in finding out what area the real problem is in...sounds like a paper jam or feed problem.
Posted on Feb 05, 2008
SOURCE: HP Photosmart 7450 stuck cartridge
not a solution, my paper feeds past the point where printer5.gif would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge1.gif appears to be stuck in far right area of cartridge track.
Replaced drivers as above and still have the same problem.
Mine started after I had replaced the color cartridge. Mailed the old one to HP already so can't put in old cartridge.
If I unplug printer from computer, I get same results. Does the driver software install in the printer?
Geo
Posted on Apr 03, 2008
Joed911
  • 4338 Answers
SOURCE: HP C3150 Cartridge stuck
  1. Press the Power button (c01575386.gif ) to turn the product on, if it is not already on.
  2. Open the cartridge door. The carriage might try to move into the access area at the right. Allow it to move to that position.
  3. Wait until the carriage is idle and silent.
  4. Without turning off the product, disconnect the power cord from the back of the product. WARNING: You will move parts by hand in the following steps. You must disconnect the power cord to eliminate the risk of an electrical shock and to reset the paper-feed mechanism.
  5. Looking in through either the cartridge door or the output tray, make sure the cartridges have not come loose in the carriage. Push each cartridge inward to securely lock them in place.
  6. Check for and remove any obstructions under or around the carriage that might prevent it from moving.
  7. Make sure the carriage can move freely across the width of the product by firmly pushing the carriage to the left, and then to the right.
  8. Close the cartridge door.
  9. Reconnect the power cord to the back of the product.
  10. Press the Power button (c01575386.gif ) to turn on the product.
  11. Allow the product to warm up, and then try the print job again.
  12. Check the cartridges for damage: NOTE: The product must be on or it will not release the cartridges.
  13. Wait until the carriage is idle and silent, and then lightly press down on a cartridge to release it. Pull the cartridge toward you out of its slot.
    • The tri-color cartridge is on the left.
    • The black cartridge is on the right.
  14. Check the cartridges for damage, and then replace any damaged cartridges. Check for obstructions under and around the carriage. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
  15. Follow these instructions to install the cartridges correctly.
    1. If you are installing a new cartridge, remove the cartridge from the packaging, and then remove the pink-protective tape.
    2. Hold the cartridge by its sides, with the contacts facing into the carriage.
    3. Slide the cartridge at a slight upward angle into the empty slot, and then gently push it until it snaps into place.
      • To install a tri-color cartridge, insert it into the left slot.
      • To install a black cartridge, insert it into the right slot. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
        Thanks, Joe
Posted on Nov 11, 2008
Obertelli
  • 3006 Answers
SOURCE: Cartridges Jammed, Paper Light Keeps Blinking
There are a number of possible causes but none are realistically fixable as your printer is more than ten years old now and has far exceeded it's design life. If you're lucky then it's just a broken microswitch.
If you want to try and see if the fault is a simple one then you'll need to remove the casing and watch the machine as it tries to operate. What follows is based on the very closely related Deskjet 880c, but yours comes apart almost identically.
You'll need a torx driver with small sized torx bits (sorry, I don't recall the exact size) and a small flat-bladed screwdriver. You'll also need paper towels and an anti-static wristband. You may also need a continuity tester to check any suspect microswitches but it's often obvious if they're broken simply be the feel of the operating button when pressed.
Disconnect the machine from the power supply and open the lid. You'll see two torx screws which you need to remove. Turn the machine over and you'll see that at each endthere are plastic tongues which have clipped into the metal chassis. Use your flat-bladed screwdriver to carefully push these inwards and at the same time ease the end cases of the machine away from the main body of the machine. keep a careful eye out for any obstructions and be aware that the right hand end case (as viewed from the front) will have wired connections which you must be careful not to strain. If there are any loose/broken parts then put them to one side.
As the right cover comes off, be prepared for many years of inky goo. If it gets on your hands they'll be stained for a few days, so use the paper towelling. This goo is the residue left from every time the printer has been through a cleaning cycle and when it discharges ink whilst priming new cartridges before first use. If the goo is everywhere, then give up and bin the machine. It won't be worth the mess and effort to clean up all of the delicate working parts which probably won't work afterwards anyway.
If you had any loose parts then now is the time to see where they came from: detective skills are useful! If the broken part held a moving component then assess whether it can be glued or replaced by a bit of lateral thinking.
Now reconnect the power supply (it's a low voltage from a transformer, so is safe) and check the printer operation. Parts which may be causing the problem are normally things like microswitches, dislodged springs, broken spring locating tabs, dislodged/broken drivebands or failed motors.
Personally though, unless you like finding out how stuff works then just bin the printer. I've had dozens of free printers and multifunction devices from Yahoo FreeCycle over the last year and many work perfectly or have a really easy to fix fault (such as Epsons which need the service indicator resetting and maybe ink pads replaced). I take them, repair them and re-offer them on FreeCycle or sell them if i've any money tied up in repairing them. Older HP's are generally extremely reliable (my Deskjet 880c has had thirteen years of fairly heavy use and going strong) but when they fail it's normally for a really good and non fixable problem.
Posted on Jul 08, 2009
Replaced cartridge won't print
Step followed:-
1. Remove cartridges.
2. Press and hold the Power Button and remove the Power Cord from the back of the Printer(in printer ON state).
3.Shake the cartridges and clean the cartridges.
4.Clean the printhead softly from cotton clothe.
5.Put the cartridges again.
6. Press the power button and connect the power cord.
7. Clean and allign catridges from printer control pannel.
This might can help you and try to put some thick paper instead of normal paper.
Apr 05, 2014 | HP PhotoSmart Office Equipment & Supplies
How do i fix a cartridge jam?
Hi andmary,
While using the HP Photosmart C4180, the printer may display error messages. These messages alert you, as the printer's user, to any problems affecting the printer's performance. The printer can display the message "Carriage Blocked" on the printer's display screen, stopping any current print jobs and preventing you from printing anything until you resolve the problem. The error message can be caused by an actual obstruction, such as a stuck piece of paper, keeping the cartridge carriage from moving freely inside the printer. Sometimes the error is a result of a software error.
Instructions:
1. Turn off the printer, wait 15 seconds, then turn it back on. Press the "Setup" button on the control panel, then use the arrows to highlight "Print Report" and press the "Ok" button to print a self-test page.
2. Remove all the loose paper from the printer's input tray. Turn off the printer and open the back door by depressing the tab on the left side.
3. Pull out any stuck paper, being sure to turn the rollers to check for small pieces of paper. Close the back door and open the printer's front door.
4. Remove any stuck paper from the printer. Move the cartridge carriage from the left to the right side of the machine, removing anything that stops the carriage's movement.
5. Push down on each cartridge, then pull each one out of its slot. Replace the cartridges in their slots, then push forward on them until they each click into place.
6. Plug the printer back in and turn it on, then unplug the printer's power cord from the back of the machine and the electrical outlet. After at least 15 seconds, plug the power cord back in and turn the printer back on. If the problem persists, take the printer to a repair shop.
Hope this helps.
Thank you for using Fixya!
Sep 24, 2011 | HP Photosmart C4280 Aio Printer
The Officejet J5780 has a error message of out of paper@
First of all make sure there is no paper pieces stuck inside the printer. Now ..!
Unplug the power cable ofthe printer.
Unplug the USB cable from the Back of the printer and make sure it is stand alone printer.
Now,
Take out the duplex-er ( A box at the back of the printer which has two buttons at the ends of it which you can press to detach it from the printer :- It is used for duplex printing ) from the back of the printer.
Once you take it out you can see the ROLLERS and the ROD which takes the printer page and rolls back to give you the out put.
Take a lint free cloth and clean the rod and rollers. Try to move the rollers in clock wise or anti clock wise direction. If it moves fine Other wise hardware issue.
Now attach the Duplex-er back to the printer.
Now Reset the printer:-
To reset it.
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say Part nvm reset.)
Now try to turn on the printer and check if it shows the out of paper option. If it works Perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer. Now close the door.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full rest )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still the problem Exist Call HP as the product has gone bad.
HP :- 1-800-474-6836 ( Tech Support )
May 07, 2010 | HP Officejet J5780 All-In-One InkJet...
Paper jam
Disconnect the USB cable from the back of the printer.
Now, First of all make sure there is no paper pieces stuck inside the printer. To take out the papers.
If you see any papers stuck inside then take it out. Now
To reset it.
Partial reset :-
Now try to turn on the printer and check if it shows the paper jam option. If it works Perfect. If not then do this :-
Semi-Full Reset:-
May 06, 2010 | HP Photosmart 3210 All-In-One InkJet...
CARRIAGE JAM WILL NOT RESET AFTER CLEARING JAM
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 06, 2010 | HP 7210 OfficeJet All-In-One Printer
Cleared jammed paper, but HP OJPro 7590 keeps giving error message that I am out of paper. Have any idea how to fix?
To reset it.
Partial reset :-
Semi-Full Reset:-
May 05, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Paper jam message no paper jam cartridge gets stuck HP 6310 all in one
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | HP Officejet 6310 All-In-One InkJet...
HP psc 2510 repeatadly tells me to print alignment page. I have put in two new cartridges
take out the cartrdiges from the printer and then clean the contact points on the back of the cartridges. then unplug the power cable from the back of the printer and then press and hold down the color copy and cancel button at the same time. and then plug back the power cable back into the printer. try to power on the printer and insert the cartridges one by one into the printer.
Nov 03, 2009 | HP PSC 2510 All-In-One InkJet Printer
Dear customer service My 2510 xi photosmart printer keeps flashing "insert black or photo print cartridge" even after inserting brand new Hp no 56 printer cartridge. Please help Mukund sargur
do one thing try to connect the printer directly to wall outlet bypassing the serge protector.
disconnect the power chord from the back of the printer. wait for a minute press the on button for 10 times .reconnect the power chord to the back of the printer .then took out the cartridges take a lynt free cloth clean the copper contacts on the cartridges as well as in side the printer where we put in the cartridges.if still the issue is there call hp tech support they might help you
the hp tech support number is 18004746836
Oct 06, 2009 | Office Equipment & Supplies
Installed new ink cartridge and it won't work
HI
did you check if the printer printed a cartridge alignment sheet.
you can try power flee initially
take out the cartridge
unplug the power cord
press the power button for 30 seconds
and then replug the cable
when it asks for putting the cartridge
put the cartrige in its respective slot
also make sure that you keep t least one paper on the tray so thst the printer prints an alignment sheet
,it shjould work fine
Hope this helps
Take Care
Jun 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
128 people viewed this question
k24674
