Question about Echo Garden
Echo PB1000 - 1990 model...just rebuilt the carburetor...the unit starts but stays in a 4 cycle mode at full throttle and dies when the trigger is released for idle...the high speed and the low speed screws are screwed all the way in...(only way it will run) it sputters and starts and dies otherwise. Any ideas to help me out? Also the gaskets had to be reversed on the top of the carb to make it run...there are two layers of gaskets on the top and the bottom of the carb. One is thick and the other is a thin one. Thanks for any help you can lend...Chris
  • 148 Answers
SOURCE: Echo leaf blower is bogging down at full throttle,
Have you tried cleaning the carb?
Posted on Aug 24, 2009
Testimonial: "Thanks for the suggestion, that sounds like what it may be. "
  • 4088 Answers
SOURCE: Husqvarna 136 chainsaw
Both H and L screws should be set 1-1/2 turns out from stop. Turn the idle speed screw two turns in from where it is now. When you had the carburetor apart, did the rubber diaphragm seem hard? If it did, re-kit the unit. When you clean the carburetor body, use spray carburetor cleaner and use compressed air to blow out all fuel passages including the two mixture control screw holes. Be sure to check the condition of the fuel line and the air cleaner. Even a plugged muffler can cause weird problems.
Posted on Sep 01, 2009
  • 164 Answers
SOURCE: Poulan Weed Eater PPB250E won't accelerate
definatley running out of fuel. this sounds dumb-just check it. the fuel line from the tank to carb is made of tygon, it gets hard and cracks allowing air to enter fuel line and lean out the unit,sometimes till it quits. also drain the fuel from the tank, look in tank, youll see a hose with a weighted fuel filter in the end of it, get a peice of wire,carfully pull it out and chack for cracks or a broken off 'clunk' fuel filter. then which is hard, the fuel pump-a little built in vacume diaphram in the carb that re-verberates with engine vacume and pumps fuel at high demand times. there will be a metal cover on the carb with a hole in the middle, carfully remove the screws ans the diaphram will be part of the gasket so dont rip it or youll need a carb rebuild kit. look for rips or tears or a broken return spring. also make sure the carb hasnt loosened up from the engine, this will cause a vacume leak and then the pump wont keep up. check the lines first that what you will probably find. good luck!
Posted on Sep 03, 2009
bbreton
  • 437 Answers
SOURCE: my echo pb1000 gas blower wants to stall at high
Yes it could need both of them plus some fresh gas mixture to boot. I would start with the fuel filter and then go to the carburetor.
HTH
Good Day.
Posted on Oct 27, 2009
dontbother10
  • 2220 Answers
SOURCE: pb1000fuel to oil mix ratio for echo
New Echo manuals say "50:1 for all engines regardless of what is printed in manual."
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Nov 09, 2009
Echo only runs wide open
Your question isn't detail enough such as.
Q: It starts up wide open with the trigger depress fully but when I release the trigger it dies.
A: The carburetor idle jet (Picture A item #27) is dirty/plugged. the carburetor needs to be taken apart and cleaned or it just needs to be turned out a bit to flow fuel or the idle screw that sets the idle speed (Picture B) on the carburetor need to be screwed in to open the flap a bit more. Your carburetor may not be like either of these two carburetors but close enough. If you need to figure out which carburetor you have to locate the idle jet look search for picture of your carburetor and that tells all such as in picture A.
Another couple things. In picture B you see the spring on the throttle shaft that closes the flap to idle. If that area is really dirty the flap could be stuck wide open. Make sure the it is free to open and close. If the chainsaw has had a lot of use the engine could be wore to the point at idle the piston isn't making enough compression for the engine to stay running even if you turn the idle speed screw (Picture B) in as far as you can.
Aug 10, 2016 | Echo Garden
Model pp4218 throttle stuck open
I assume you are referring to a pullen pro chain saw. If so, the cable that links from the trigger to the carburetor is stuck. This can happen due to trash and dirt stuck in the trigger area, or the carburetor needs cleaning. Or the cable or wire to the carburetor is bent. See if the connection between the trigger and carb moves freely when not running.
May 02, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
After replacing primer bulb, engine hesitates and will not run full throttle
Make sure you connected the lines correctly. If this is a primer assy that has the 2 barbs on the back here is a picture of how the lines should be connected to it as well as the carburetor
Now if this is a primer bulb on top of the carburetor then disregard the previous answer because in this case, your carburetor needs the H needle adjusted. Go on you tube .com and type in how to adjust a 2 cycle carburetor. Many videos will appear.
Nov 21, 2015 | Garden
I have a ppt-260 that when cranked it runs at a high rpm without pulling trigger and does not return to idle, does anyones have a suggestion for a fix?
Check your throttle cable as it may corroded and has the carburetor held in full throttle position or someone has the idle speed screw turn all the way in.
Nov 22, 2014 | Echo Ppt-260 Chainsaws
Mantis will only start if i squeeze throttle
The carburetor may need cleaned or rebuilt, empty out the fuel and put new in if you have not already. If that doesn't work remove the carburetor, clean it and inspect the diaphragm (small engine shops will do this as well if you don't feel comfortable). Echo engines are great runners but this is very common- rebuild kits and brand new carburetors are available online. The work can be very quick and easy if you are careful and patient, if not then leave it to the pros.
May 20, 2014 | Mantis 2-Cycle Tiller
Just purchased a new FG 110 tiller it seems to run fine for a while then I have to release the throttle to keep it from stalling out. It has less then 20 minutes of use. I have installed the oil. It will...
It sounds like you may have a "lean" carburetor mixture setting on the high side or full throttle. This carburetor may have limiters or special screws that will make it difficult for you to adjust. You may try contacting a dealer to see if they could try adjusting it for you or just take the unit back.
Feb 20, 2011 | Honda 25cc 4-cycle Mini Tiller
Chainsaw runs wide open
Operate the throttle trigger to see if it returns to the idle speed screw when the trigger is released. If it seems to 'float' somewhat, the trigger assembly may be full of dirt/sawdust, or the throttle return spring on the carburetor is damaged or disconnected. When taking the trigger assembly apart, be sure to make notes so that it can be put back together correctly. Make sure the throttle plate in the bore is tight to the shaft. When the carburetor was off of the engine, did the gaskets and heat insulator seem to be ok? Any air leak behind the carburetor will cause run-away speed. As for the engine quitting, check the fuel filter, air cleaner, and muffler for plugging. Check the condition of all of the fuel lines for decay or other damage. Did you check the condition of the diaphragm in the lower chamber of the carburetor--it should be quite flexible with no holes or cracks. With the jetting set where you have it, the engine should be 4-stroking heavily. Hope this helps!
Jul 20, 2010 | Poulan Pro Chain Saw 46cc 20"
I have a troy bilt 4 cycle. I have had it for
clean the carburetor. and make sure the screen in the carburetor is clean and clear. your best to take it out and spray a drop of carb clean and burn it off. also make sure the fuel filter is clean to. the diaphrams may be a little stiff so clean them to.
May 02, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
My Echo power edge trimmer starts and idles fine. When I try to throttle up it begins to die out. I can get it to run at a slower speed, but to get it to maximum rev it dies. I replaced the spark plug,...
I was having the same problem and stood there while the tech fixed it for me. I could have done it myself; honestly, nothing to be afraid of. Take the air cleaner off and then take the carburetor off and start taking it apart layer by layer (remove screws and take pictures with a digital camera of how to put it back). It is not complicated and it was a small piece of grass stuck where you never thought it could get that allowed a start but not full throttle.
Apr 18, 2009 | Echo Garden
Garden Logo
37 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
