Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
I am losing wireless connection - Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
  • Westell Wire... Master
  • 32,281 Answers
A disconnecting wireless can be caused by any number of things. please click on this link and follow my instruction for a possible solution.
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Posted on Apr 09, 2011
Losing network connection
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 19, 2012 | Toshiba Computers & Internet
Losing internet connection
Aug 29, 2012 | Zyxel Prestige 100MH Router
Internet connection lost every 30 minutes
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
May 22, 2012 | D-Link Xtreme N DIR-655 Wireless Router
I can only get wireless internet when plugged directly into my wireless modem. Why do I lose connection when I unplug?
If your wireless card in your computer/laptop has not been configured with your wireless router's settings then it cannot connect to the wireless router. That is why you lose Internet connect when you disconnect the LAN cable.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 03, 2010 | D-Link /Netgear 4 Port 802.11 b Wireless...
My imac loses its wireless connection, regains it,
Best place to look is ebay as these cards are nolonger made. First try and plug and unplug your card a few times.
May 13, 2010 | Apple Airport Card - Network adapter -...
Loses the connection
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Feb 07, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Laptop keeps losing wireless connection
make sure the wep key you apply it is correct.just reconfgure the wireless connection.
Dec 31, 2009 | Dell Inspiron 6000 Notebook
Losing wireless Connection
No solution known to fix this. Internal the software tries to refind itself.
In Linksys software there are two separate programs running. The video is sent to the wireless router and recorded on your computer. Whether it is alive or not and can be configured is a different program. That program requires the wireless camera be literally just a few feet from the wireless router. Say 5 feet or less. One configured you can move the camera to well over 100 feet from router fine.
But eventually it will lose connection and you have physically move camera back.
This is a major flaw of this system and why it won't work for a real application
Jun 20, 2009 | Linksys Wireless-G WVC54GC Network Camera
D-Link DIR 655- losing connection with ntwk is "INVISIBLE"
unfortunatly it is my understandingthat blackberrys require an ssid to connect as they are not as advanced as a laptop or wireless adapter on a pc...sorry
Dec 11, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Connection trouble
I purchased linksys WRT54G when I connect the second wiring I
lose my internet. My wireless use to work but since I disconneted it and reconnected the wireless does not work.
Jul 11, 2008 | Linksys Wireless-G WRT54G Router
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
75 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
