Just out of box new model 246 powers on sayes HELLO THEN GOES TO STANDBY no functions
  • ralph dudley Apr 09, 2011
    can the remote be over riding thestart up and causing it to go to standby
  • 11,800 Answers
Hardware defect - it's processor cannot finish the loading of the firmware. This is terminal, the entire mainboard (on which the processor and the firmware memory chip are soldered) will have to be replaced.
Since this is a brand new object the defect is clearly a manufacturing one, covered by the warranty - under no circumstance do not try to open or do anything to it, you will void the warranty. Just take it back to where you purchased it and replace it, this one is pretty much dead.
Posted on Apr 09, 2011
  • Azrael SRL Apr 09, 2011
    Highly unlikely - for that to happen it would need to be constantly operational; that would mean that the unit will power on and simply in the presence of the remote, without pressing any buttons on it. Since you need to press the power button it means that the remote is good and the defect is in the unit.
    Brigadier General:
  • 3,917 Answers
Hi
Since the problem is not desirable, hope there is something wrong with the set up.Please check the bellow link to read the article on turntable and the set up:-
http://www.ehow.com/how_2070794_up-basic-dj-turntable-set.html
http://www.dj-advisor.com/cd-turntables.html
If the problem won't get cured you are suggested to contact the dealer since it's a new one and hopefully under warranty. So before you fumble with the inner mechanism inform the dealer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Logik TV stuck in standby
if you don't hear a click its the power over switch. on the power board it is a black box. if you have the back off turn the tv on and then out of stand by and flick the black box it will probably turn on.
Feb 25, 2014 | Televison & Video
No power on (LCD27TV006HD)
Does the standby light continue to blink? IF so, count the number of blinks and go to:
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
That may help you decide what is going on.
In the long run you will probably need to have a tech take a look at it. The problem you describe is usually a serious matter that needs repair by a trained technician..
Goodluck,
Don't forget to rate me as fixya...
Feb 03, 2008 | Televison & Video
E725 notebook goes to standby
Go to control panel, power options, look down to the left to system standby and select never from the list, next! top right "hibernate" click, and make sure hibernate box on the left is unchecked, and close window. This should solve the problem computer going to sleep.
Apr 23, 2012 | Acer eMachines 5202496 PC Notebook
I found a ilo 32 hdmi t.v. model lct32ha36, there is not a button that says on/off. Just a standby. I want to figure out if it works before I by a remote to test it. Can you suggest anything?
Most new televisions are actually labeling the "power" button correctly. Unless a tv is unplugged, it is never really off. It just goes into a state of standby. This is what you would have called your power button.
Jan 03, 2012 | iLO Televison & Video
Mö m öçöççöçöçömıoujkhnkjönmön
Hello, welcome to Fixya!
How may I help you?
Apr 25, 2011 | Samsung Jet S8000 Cell Phone
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Standby mode intermittently.
Hello, FixYa
I have normal tv model CNT 2588 code 981, remote control was out of order and I tried to buy a new one from many places in UAE, Suadi Arabia & Egypt but I failed due to it is old model and no spare parts. So I use the tv function through Satel Decoder and use tv main power button for swithing on and off. It seems that caused a problem and tv now could not get power to switch on. Would you e-mail me with the repair manual including the Elect.Circuit to try to repair the problem. Also if you can arrange to send me a new remote control model CNT 2588 code 980. Since the TV Picture and sound are still in an excellant condition, please e-mail me you kind response with the cost if any to send you my Address and money.
Thanks in advanced.
Mohamed Said
Oct 30, 2008 | Televison & Video
Standby mode on dvd player
Has it recently been zapped by lightning? Ive never heard of this happening but i can tell you its not a problem you can fix. I suggest getting your money back or exchanging it for a new one.
Nov 29, 2007 | Sony DVP-NS400D DVD Player
Power on problem
Many of the later model Sony TV?s have a built in self-diagnosis function. AKB circuit (automatic kine bias), the timer/standby indicator blinks 5 times for about 30 seconds then goes to the self-diagnosis function. In other words, the IC chips on the Cboard are burned out. This repair is not one that should be attempted by the end user. This repair will need special test equipment. You will need to take it in for repair. It shouldn't cost more than $170-$200. This is cheaper than a new TV set.
Jun 23, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
122 people viewed this question
 Grubhead
Grubhead
