Question about Hitachi Cpx2510 Projector Cpx2510 Xga Projector Lamp
My hitachi projector lamp is continue blinking and reb light are show what is problem
  • Hitachi Master
  • 6,694 Answers
hi,
Check the lamp cooling fan of your projector . may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
Also check the air filter. try to clean the air filter.
ok
Posted on Apr 09, 2011
Green light on prjector PRM 35 will not stop blinking and the projector will not come on
open the case, and reseat the ribbon cable at both ends.
5 screws on the bottom and 3 screws inside the lamp housing to open the case. Be careful not to break the 2 plastic clips in the back.
Also check the micro switch on the lamp door is working correctly.
Mar 10, 2014 | Promethean Board Promethean PRM-35 DLP...
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
The Lamp light and Temperature light is blinking red while the projector is running
Clean the filters and check the lamp before it is too late and the lamp bursts or the LCD units burn.
Jan 07, 2011 | Hitachi CP-X250 Multimedia Projector
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
My Hitachi CP-X275 Multimedia Projector will run then shutdown by itself and not show a picture.
Normally when a unit like this shuts down, there are indicators that will show why. Are any of the lights on or blinking when this happens? The most common cause is overheating. Is the lamp indicator RED or the temp indicator? A little more detail would be helpful here. Can you also indicate how long the unit runs before shutting down?
Thanks,
Dan
Nov 04, 2010 | Hitachi CP-X327 Multimedia Projector
My projector will not come on. the power light blinks green, then goes to red. the "lamp" light looks like it is coming on dimmly (red)
you need a new lamp:
http://www.shopvsc.com/Replacement-Lamps-for-Hitachi-Projectors-s/291.htm?searching=Y&sort=9&cat=291&show=50&page=1&f-CP-X201=105087
Oct 27, 2010 | Hitachi CP-X201 Projector
Hitachi 50V500
Sounds like the lamp has gone or the filter needs cleaning.
Aug 21, 2009 | Hitachi UX21511 Projector Lamp for 50V500
Hitachi Cpx2510 Projector  Cpx2510 Xga Projector Lamp Logo
823 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
