When i unplug my rinnai heater does that turn off the pilot light?
    Brigadier General:
  • 4,736 Answers
If it's a Vent-free (Vent-less) heater, not it does not turn OFF the pilot light. If it is a Vented Heater, yes unplugging the heater will turn the pilot light OFF. If you want to turn the pilot off on either unit, the best way to do it is with the Gas Valve, Pilot Control Knob. Turn the knob from the ON position counterclockwise to the OFF position and the pilot flame will go out.
Hope this helped you.
Posted on Apr 09, 2011
I have a rinnai 30000 btu floor heater. The pilot will not stay lit. I have installed a new thermocouple please help
Contact rinnai support ,make sure the pilot sensor is sitting in the flame,& i hope you did not over tighten it when installing it also lightly sand the end that screws in.
Feb 21, 2015 | Rinnai Heating & Cooling
Have a rinnae royal gas lok heater. Cant start it after gas was shut off. How do you get the ignition to work and start the pilot light again
When the gas was turned OFF, air got in the line(s) and created an air pocket. This air will need to purged from the system, before the heater will light. It only the shutoff valve on the gas line to the heater was turned OFF, it will be easier to purge. If your Rinnai heater has manual ignition rather than electronic ignition. Holding the control down in the Pilot position, will eventually purge the air. If you have electronic ignition, continually trying to light the unit will do the same thing, but take longer to accomplish. Consulting your Rinnai will also help you with this situation.
Hope this helps you and thanks for choosing FixYa.
Jul 28, 2011 | Rinnai Heating & Cooling
The pilot light on the Rinnai gets blocked with
the heater needs service /cleaning along with the pilot to findout why this carbons up
May 12, 2010 | Heating & Cooling
NO HOT WATER N THE PILOT NOT LIGHTING UP
The thermocouple has gone bad.The thermocouple needs to be directly in the pilot flame.When the thermocouple goes out,the flame most of the time will have burned the thermocouple tip a way.If it was not for this devise,the gas would exscape,and fill the home up.This is a safety feature.
Oct 20, 2009 | Heating & Cooling
Where is the pilot light on Rinnai EnergySaver 1001F
If you smell gas in a Rinnai you have a big issue. This heater is what is called a direct vent heater with an electronic ignition so the combustion chamber is sealed and the smell of gas is an indication that you have a gas leak. Please call a professional today.
Oct 13, 2009 | Rinnai Heating & Cooling
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Infared heater
When was the last time you cleaned the pilot? In your owners manual there is a cleaning procedure. If you can't find the manual, go to www.rinnai.us. You may be able to download one from their site.
Dec 18, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
