Question about Watches
ROLEX SUBMARINER 27JEWELS MODEL NUMBER NOT ON BACK OF WATCH ? BAND NUMBER 62510H
  • 3,018 Answers
There should always be a serial number on the back of the case period. If your Rolex does not have any indicators on the back it is not authentic. Sorry. One thing to always note is if you get a 10x eye loop and look at the writing on the case and bracelet if you notice it being sandy colored and or punched several times rather than one smooth form this is also not authentic.
Regards, Tony
Posted on Apr 09, 2011
Can I do a check threw serial numbers
The most secure way to check a Rolex is to go to a specialized trade. The following Link gives you a overview of specialized dealers available in USA: http://www.rolex.de/de/rolex-dealers/dealer-locator/unitedstates
Best Regards
Mike (Germany)
Sep 27, 2014 | Rolex Submariner 16618 Wristwatch
What is the number 381 on the back of my watch mean
For Casio watches, the number on the back is the module number. For ROLEX I have no idea. Never saw one in my life.
Aug 31, 2014 | Rolex Oyster Perpetual Submariner Date...
Adjust the bracelet
There are tiny pins either side of the wrist band next to the clasp. Remove these pins and you can take out up to two links (and a half link on some models.)
A jeweller could do it, needs a special tool to tap them out and put them back
Nov 03, 2013 | Rolex Oyster Perpetual Submariner Date...
Rolex oyster submarine model 62510H .NEED TO KNOW THE YEAR
Actually the information from Ironfist109 is incorrect. Rolex has the serial number between the lugs at the six o'clock position. The number between the lugs at the 12 o'clock position is the caliber number. Shouldn't be anything on the caseback, very rare with Rolex. Often is a good indicator it may be fake actually!
Dec 19, 2011 | Rolex Submariner 16618 Wristwatch
Where are the model number and serial number on a rolex
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    I have a rolex submariner and it occaisonally vibrates. What is the problem with this.
    Sounds like mainspring is not holding in place and getting undone (unrolls by itself), that what usually causes the vibration.
    W-Precision
    Mar 19, 2010 | Rolex Daytona 116520 Wrist Watch
    How to shorten band on Rolex submariner
    on mine I removed a couple links using a jeweler's screwdriver(flat-blade). Look for the screws in a hole along the narrow edge of the links nearest to the clasp. Use care in removing/replacing these screws, you do not want to break or strip them using excessive force. If you need to remove more than one link, take additional links from the opposite side of the clasp, so the clasp stays centered on your wrist.
    Nov 06, 2009 | Rolex Submariner 16618 Wristwatch
    I can not open the back cover of my Rolex Submariner, I hear something rattling inside.
    If the watch is working okay, and it is a self-winding model (i.e. it doesnt not have a battery which relatively few Rolexs do) then the noise you probably can hear is the self-winding mechanism.
    Rolex backs are very, very difficult to remove and watch repairers have special tools to do so. As a Rolex is an offically certified chronometer, and therefore has an incrediby accurate and complex mechanism, the backs are deliberatly designed to be difficult to remove by just anybody.
    Oct 01, 2009 | Rolex Daytona 116520 Wrist Watch
    Submariner 16610 M Model has 40 seconds faster
    I don't know if I can help you out, but I can tell you that even a low quality Daytona, or Submariner copy can be adjusted. My 1992 Daytona copy is at about 10 sec a month fast. I read a **** load about the movement, and did the adjustment myself. Any watch shop that tunes watches can do it.
    I don't know what year your Submariner is, but today Rolex is using a new main spring (it is now blue). I would think a replacement spring would be the most you might need, but a good tune-up should do the trick. If it is real, I would think about sending it to Rolex for cleaning and a tune-up ($$$).
    Jan 27, 2009 | Rolex Daytona 116520 Wrist Watch
    Watches Logo
    26 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
