I have F/#2.0 f:4.8mm USB Webcam , but i don`t see vzo and skype ... how can i slove that ? System port and all device are ok .
3 Suggested Answers
SOURCE: HP Deluxe Webcam on SKYPE 4.0-friends can hear but not see me.
hello you've probably given up and binned the cam by now - we nearly did. but solved it last night. It's the annoying photo editing program that opens automatically when your camera opens up that's interfering with Skype. called magic-i or something like that. Remove that from your comp and the camera works fine. good luck!!
Posted on Apr 13, 2010
  • 376 Answers
SOURCE: MY WEBCAM INTEX IT-305 WEB
It sounds like you have a USB port(s) problem. Did you check them in Device Manager to see if they work ok? Did you try a different usb cable? You surely need Windows Service Packs installed in order to get USB 2.0 compatibility and speed. Without the service packs you will only get USB 1.1 compatibility and speed. But of course, the USB controller must be a USB 2.0 Controller before it can attain USB 2.0 compatibility and speed. There is no software that will make a USB 1.1 controller a USB 2.0 Controller. If your current USB controller is only 1.1 compatible, you will need to obtain a high speed USB 2.0 controller card or bus card. The easy way to tell if the current installed usb controller is 2.0 is to open Device Manager and click the + button next to USB Controllers. If you see the word "enhanced" anywhere beneath, then the controller is a USB 2.0 controller.
Posted on Sep 09, 2010
My webcam not work properly
Is this a Web cam that is integrated in your laptop?
If you are using a Windows XP or Newer, I would suggest going to Start>Control Panel>System and Securites> Under System> Device Manager Click on images Devices and right click on the sub menu below images Devices and uninstall the webcam. After doing this, Restart the computer and the the driver file should reinstall you webcam.
Jun 16, 2013 | Toshiba Computers & Internet
Skype crashes when the webcam gets operational windows 7, skype 5.3, creautive webcam
> update your device drivers.
> Clean your system and registry using some reliable cleaner such as Reginout Cleaner.
> Scan and clean your system using some powerful antivirus program.
Thanks
May 08, 2011 | Computers & Internet
I plug my camera into the usb port and try to go on skype and my camera isnt recognized
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or
update driver
hope this helps
don
Feb 22, 2011 | Logitech QuickCam Fusion Webcam
How do I connect my Logitech webcam to my free skype?
Connect the Logitech Quickcam into the computer's USB port.
Install the Logitech Quickcam device driver.
Open Skype then click on Tools - Options - Video settings.
Select the WEBcam - Logitech Quickcam and you should see your image in front of the WEBcam.
You can set options for people to view you etc. Then click SAVE.
Oct 16, 2010 | Logitech Quickcam Chat Webcam
I have a logitech webcam and have been using logitech software. My friend only uses skype. Will there be a great cost difference if I use logitech and he uses skype? Should I download skype so that we are...
You can download skype for free
http://www.filehippo.com/download_skype/
Set up
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
Set your webcam mic as default ( if it has a built in mic
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Aug 20, 2010 | Logitech Quickcam Chat Webcam
I have bought a Gigaware webcam 25-157 and it doesn't work for skype. Could you please provide an assistance in order to get this webacam work with skype. Thank you
Working OK ?
Plug in the webcam
TEST SPEAKERS
Restart computer
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
Aug 08, 2010 | Radio Shack VGA PC Camera Webcam
I am new at using Skype. I have had a logitrech Communicate stx Web Cam installed. I notice there appears to be what one would think are microphone holes at the base of the lens as well as the writing...
You are correct.
For Logitech to work with Skype you need to install the Logitech driver for your model WEBcab. Then you need to configure Skype to use the Logitech WEBcam and microphone.
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
If this works then configure Skype. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Also check the Audio Settings for the Microphone THEN click on Save.
Avoid connecting the WEBcam to an USB hub, connect it directly to the computer's USB port.
Jul 05, 2010 | Logitech QuickCam Communicate STX Personal...
People cannot see me on my webcam on Skype
Before you can use your webcam in any chat program you have to configure it to that program
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
Mar 23, 2010 | Philips SPC530NC VGA Webcam
Pc restart when i try to use webcam on skype 4.1.0.166
hmmm! it may b ur RAM probz!!! chek cam settings! may tht USB port affecting ur RAM wich results in restarting!!
Nov 10, 2009 | Logitech QuickCam Pro 9000 Web Cam
Computers & Internet Logo
347 people viewed this question
David Payne
David Payne
