Question about Whirlpool Dryers
Drum does not turn.- hums, then electricity kicks off. - slight burning smell I have not had a problem with element
  • 3,018 Answers
Sounds to me like your motor has shorted and is throwing the circuit breaker. I would first check the connections and then get down inside your dryer and remove the belt so the motor has a free ability to turn and try to spin the pulley by hand. If it has some hang ups then the motor is bad. A burnt smell coming from it would also indicate this. Make sure to unplug the dryer before doing any inspecting or replacing of parts.
Regards, Tony
Posted on Apr 09, 2011
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
Condenser dryer not running
see this possible causes:
Power from the house
test the c. breaker for tripped or blown fuse
Door switch
test the switch for open and replace
Thermal fuse
tes the fuse for open and replace
Wiring
test the wires, for open, broken, loose or burn and repair
God bless you
Jun 18, 2012 | Zanussi Dryers
My dryer hums but the drum doesn't turn unless I assist it and then the dryer kicks on. The selector switch automatically turns on when I move from the "off" position (the start switch is...
Hello, Thank You for using FixYa. I will be helping you today.Its the switch in the motor thats bad.Thatmay have been the smell the motor burning up.Replace the motor
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Frigidaire GLER642A Electric Dryer
Dryer smells like something is burning and making a slight humming sound
check tub bearings and/or rollers or for anything that could impede the turning of the tub. Sounds like something is stopping the tub enough
to make the drive motor turn on the belt causing it to burn and smell.
If you fix the problem with the tub be sure and change the belt
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer powers up but won't start - smell of electrical burning. Is it the motor bushes? zanussi TC7103W
Electric dryers usually have a motor with a switch that prevents the heating element from being powered until the motor is spinning. In series with this are limit switches to prevent overheating if there is too much lint or too little air flow around the heating element. Also, the motors are induction or brushless. So the smell is coming from the heating element burning off some lint nearby as it reaches the high limit temperature and shuts off. This can be due to two conditions if we can assume the motor is running (has a switch that is closing to power the heating element). The most likely condition is that the drive belt is off the pulley or broken and the drum is not turning. You will be able to tell this easily by sounds or by opening the door to see the drum slowing down. If that's not it, examine the blower which forces air through the drum. There are a lot of variations, so look for air intake and drum exhaust ports that can be clogged with a sock, lint, etc.
Dec 12, 2009 | Zanussi TC7114W Electric Dryer
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Compresser will not kick in and there a electrical smell
Stop it!
Something has gone wrong and needs to be repaired. It's an electrical problem. The more you smell it, the more stuff is getting burnt. Take it apart and look inside it. Then restart it. The burning stuff will lead you to the bad part.
Jul 27, 2008 | Dometic Rooftop RV Air Conditioner
Dryers Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
