Turn tv on black screen AND NO SIGNAL FLASHES ON TV
  • 163 Answers
SOURCE: no picture
Sounds like one of the CCFL's is failing.. (Backlight bulbs).. Some use multiples and others have singular.
Posted on Feb 29, 2008
SOURCE: Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Posted on Nov 03, 2008
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Posted on Mar 24, 2009
SOURCE: When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
Posted on Aug 02, 2009
panchal643Ja
  • 243 Answers
SOURCE: tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Posted on Jan 23, 2010
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Feb 26, 2015 | Televison & Video
I have a shard aquos LCD tv. When I turn it on, everything comes on for 1-2 seconds, then the screen goes black. If I turn it on and off again (about 10-15 times) the same thing happens. Eventually, the...
When the tv have this problems dose the tv Power and OPC lights indication flashes together?Yes,than the tv main Tuner signal board it is dying and shorting out.Happen to my Sharp Aquos 46' tv many times but it only take about 2 or 3 off/on to get the tv backlight lite and the tv to work.U can do some mechanicals work wright?Like take thing aparts and putting it back togther again?Yes?The tv Tuner signal board that the board where the tv incomming broadcasting cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
Aug 18, 2011 | Sharp Aquos LC-32D40U Television
Our sharp LC-37D6U does not turn on. The opc/dl light keeps flashing green X3 then every second or so. and the blue power button flashes also. What might we have to do to solve the problem? thank you
The main tv Tuner signal board it is dead or it have problems,but tv still usable.Tries push the remote power switch off/on again everytimes OPC/Power LEDS lights flashes.Have to do this maybe 3 or 4 times for the tv to have a lite up LCD screen panel backlight to make the tv Tuner signal board to work again,for the tv to work.If still have same problems after 3 or 4 times power switch pushes off/on still have OPC/Power LEDS lights flashes.Mean the main tv Tuner signal board it is dead and can not be trying to save it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.This solution 100% will work,if ur tv main Tuner signal board still have life left in it.I do this every few days out of a week for my 46" Sharp Aquo LCD tv set,tv it work all the times.
Jun 12, 2011 | Sharp LC-37D6U 37 in. LCD Television
No sync signal
I'm watching live TV or recorded TV and it flashes up with a black screen saying "no sync signal".......turn TV off and then on and its all ok??????? anyone?????
May 04, 2011 | Hitachi 55HDT79 55 in. Plasma HDTV
The TV turns on, after about a minute the screen goes black. The green light which indicates the power is on flashes. After about a minute again the picture comes back on, and so on. When looking at the...
The tv Tuner signal boaard is dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 21, 2010 | Sony KDS-60A2020 60" HDTV
Screen on LG goes to black right after turned on.
It looks as if the backlights are being switched off at start up, this will be due to a fault either with the inverter board or a fault with the screens backlights which would mean the screen needing replaced. Contact your repair centre to have an engineer give you an estimate on the cost of repair.
Oct 24, 2009 | LG 20LS7DC 20 in. LCD TV
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Turning off TV
I have the same model. It is normal for this brand of tv.
Mar 31, 2008 | Sylvania 202SL8 TV
Televison & Video Logo
Top Televison & Video Experts
