Question about Boating
1986 E40ELCDE How do you take the VRO out and replace it with fuel pump? Icant get any fuel to engine
centralvalle
  • 386 Answers
SOURCE: engine was flooding out\now fuel primer has to be used to run
recheck float level as well as needle and seat for sticking and or damage, just crack line to bleed air , and eventually it self bleeds anyway... also unless you replaced with new floats check float weight with a float scale to see if floats are saturated or have fuel inside making the heavy and inaccurate ...
Posted on Aug 04, 2009
techbuster
  • 5081 Answers
SOURCE: info. on 1986 ford diesel engine
Your fuel pump would be located in the gas tank. It is mounted on the pick-up tube/sending unit assembly.
Posted on Sep 29, 2009
  • 86 Answers
SOURCE: vro pump on a 92 johnson 150hp
If you are having problems with the VRO then I would just remove or disable it and mix your own fuel. It is cheaper and there have been alot of problems with those going out while the engine is running and then they sieze their engine because of the faulty VRO. Mix your fuel 50:1 and you will be able to run all day!
Posted on Oct 16, 2009
  • 645 Answers
SOURCE: have replaced fuel pump, relay & fuel filter.
have you checked to see if you have a bad came or lifter. that would make it backfire. if it kind of spits fuel it maybe cam. if it throws fire than it could be timing like a bad chain.
Posted on Feb 12, 2010
  • 14036 Answers
SOURCE: not getting fuel to carb, mechanical fuel pump replaced.
SOUND LIKE STOP UP FUEL LINE.OR SOCK IN FUEL TANK STOPPED UP WITH RUST AND DEBRIS.YOU COULD HAVE A WORN FUEL PUMP PUSH ROD OR CAM SHAFT LOBE WORN WHICH DRIVES THE FUEL PUMP PUSH ROD.
Posted on Apr 28, 2010
Fuel Pump Location
The 2.8 engine in a 1986 Century uses a carb instead of fuel injection. So it uses a mechanical pump that goes in the side of the engine.
Jan 21, 2014 | 1986 Buick Century
Evinrude 120 vro outboard floods easily on startup , could spark plugs be wrong type
No,check vro fuel pump diaphragm.if primer bulb doesn't get hard when priming is a sign of needle and seat not sealing or a hole in fuel pump diaphragm.
Sep 08, 2013 | Sierra International 18-4310 Marine...
Not getting fuel to carb, mechanical fuel pump replaced.
Apr 28, 2010 | 1986 Chevrolet Chevy
Vro pump on a 92 johnson 150hp
Sep 30, 2009 | Boating
In the control box of an evinrude 115 vro v4 is an alarm why does it go off every 15-20 min when the motor running
The warning horn on a V.R.O. system ( variable ratio oilier) warns you of three problems. (1) LOW OIL. means the remote oil tank in the boat is near empty or empty(2) NO OIL. means there is no oil getting to the V.R.O. .problem is, clogged line or the diaphragm in the V.R.O is blown.(3) OVERHEAT. means the engine is overheating. The V.R.O is you lift and pressure pump for fuel and oil. plus it mixes the oil and gas to proper ratio. Three warning, three senders. LOW OIL sender is in the remote oil tank in your boat. NO OIL sender is in the V.R.O.. and the OVERHEAT sender is on one or both cylinder heads of a the engine depending on the year model
Sep 02, 2009 | Boating
Engine was flooding out\now fuel primer has to be used to run
Aug 04, 2009 | Boating
Hello, I have a 1986 ford e 350 Bus/van with a 5.8 gas engine,i replaced the fuel filter near the carb , it has an inlet fuel return and supply to the carb, it will start up and run and then dies, it has...
BACK IN 1986 IF YOU HAD A MECHANICAL FUEL PUMP LOCATED ON SIDE OF ENGINE. YOU HAD CARBURATOR ENGINE.AND ELECTRIC FUEL PUMP IF YOU HAD FUEL INJECTION.ENGINE.THE FUEL PUMP IS IN GAS TANK.OR MOUNTED ON THE OUTSIDE OF GAS TANK.
Jul 26, 2009 | 1986 Ford Econoline
1986 BMW 318i;Turns over but engine wont run.I'm
Fuel pump may be getting weak. If pressure is not high enough the injectors wont open.
Jun 27, 2009 | 1986 BMW 3 Series
Replacing engine with a crate engine
You have to get new gaskets like head gasket, valve cover gasket, water pump gasket. You'll need an alternator, if it has a/c you'll need an a/c compressor; you'll need a serpentine belt.
Oct 09, 2008 | 1986 Chevrolet C1500
Boating Logo
142 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
