Question about Lenovo IdeaPad Z560 Notebook
I am not getting display on lcd,i am getting external display
  • Lenovo Master
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Apr 09, 2011
Hp laptop no longer connects to external display via fn + f4
The Fn+F4 button toggles between the LCD and external monitor.
From LCD only or both LCD and external monitor or external monitor.
only. Press the Fn+F4 keys again to toggle the various screen selections.
Sep 16, 2012 | Computers & Internet
My laptop benq r56 work with wierd coulours white screen
Here are some steps which you can try.
- Plug in an external monitor and check if you get the same colors on the external display.
- If you get the same display, install an updated driver for your video card. But if still the same, your video card needs to be replacement (if dedicated) or your motherboard needs to be replaced (if integrated).
- If you external display works fine then the problem is narrowed down to the LCD. Either the LCD inverter or the LCD cable is failing and needs to be checked/replaced.
Hope this helps.
May 27, 2011 | BenQ JOYBOOK R56 154 WXGA CCFL Glossy LCD...
On an Acer Aspire 1640z I get blue screen and lines. lines move with track pad movement. nothing readable. replaced lcd cable and inverter. thinking either lcd or motherboard
Hook it up to an external monitor. If the display is fine on the external then your gpu on the motherboard is fine and the LCD is bad. No external display means bad board. Both cost roughly the same but an LCD is much easier to replace than the board.
Apr 07, 2011 | Acer ASPIRE 1640Z COMPATIBLE LAPTOP LCD...
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
My display is either all black or all white. When an external monitor is attached, the display does work on the external monitor. Everything else works just fine when the external monitor is pluged inn
It's either the lcd itself the the lcd cable has become loose, either way you're going to need to take the lcd housing apart to make sure the cable is nice and secure (both ends - 1 to lcd itself, 2 to motherboard)
If the cable is nice and tight and you get the same results then for sure the lcd needs to be swapped out.
Oct 29, 2010 | Toshiba Satellite A305D-S6848 Notebook
Line on laptop display
The line on the display is generally caused by a bad LCD inverter cable and generally requires a replacement of the LCD.
Connect an external monitor to the laptop , Tap Fn+ F8 key to toggle the display to the external display. If the picture on the external display looks good you need to replace the LCD kit
If the display also has a line , the problem is with the motherboard
Thanks for using Fixya
Proton
Oct 13, 2010 | Dell Inspiron 1100 Notebook
Blank screen,pwr sup appears to ok, fans runs, pwr light on
The issue seems to be due to defective video card on the notebook. Connect and external monitor to the PC and check if it works fine or not. You can follow the steps listed below to connect an external monitor.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your PC is under warranty, contact HP to get available options to get the notebook repaired under warranty.
May 26, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
No LCD Display, No External Monitor display
If you just replaced the systemboard, the video chip is not likely to be the problem. I would say to check the cable connections and the actual lcd, but you said that the external monitor is not working either and that is not dependent upon the cable or lcd. I would say that your systemboard is probably DOA, but just to be sure do you have another laptop to test it on?
Feb 18, 2009 | Toshiba Satellite M105-S3004 Notebook
External Display Screen
you just need to get the external LCD replaced...not to worry most lcds on the v3 you can take out the external lcd without replacing the entire lcd....so take it to a repair center close to you.
Dec 20, 2007 | Motorola Mobility RAZR V3
Lenovo IdeaPad Z560 Notebook Logo
47 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
