Question about Saitek Aviator AV8R Joystick
I lost the disk for my av8br-01 and now have trouble making configurations.
I had this router connected to my desktop so my grand daughter could use her labtop,my desktop crashed and I had to replace my hard drive and my memory and lost all information on the router and I lost the...
You actually don't need a setup disk for setting up a router. Try the following steps.
  1. Reset your router to default configurations by holding the reset button for 15 seconds.
  2. Make sure your desktop is set to "obtain an ip address automatically."
  3. Connect an ethernet cable between your router and desktop.
This should get you connected to the router. If you want to make any configuration changes, perform the following steps.
  1. Open up a web browser.
  2. Type in the address bar 192.168.1.1 (Default IP address of Linksys routers)
    This will connect you to the router.
  3. It will prompt you to login. The default username is blank (no text at all) and the password is admin.
Feb 26, 2011 | Linksys WRT54G2 Wireless Router
Hello, I have a SONY MVC-FD85 Digital Camera. When I place the 3.5 disc in it, it makes a whirring sound for about 10 seconds then reads FORMAT ERROR and a blinking C:13:01 Fixable or is it toast?...
If you have the error c:13:01 on a 256M or smaller, put it in the camera and format the disk from the camera. Put the camera in setup up mode ( on the knob) scroll down from camera set up to set up 1. Format is 1st selection, Go to Ok, Go to Ok. This should solve the problem
Sep 13, 2008 | Cameras
I have a technika webcam model:H16WC-01 and i have lost the disk how do i install it now?
You can download the drivers from here:
http://rs448.rapidshare.com/files/215871588/Technika_H16WC-01.zip
Aug 10, 2010 | Cameras
Lost my disk for Router in the move.What can i do
The really don't need a disk - just plug it in and go. You may need the directions (default IP address) which can be found at the linksys website.
Feb 05, 2010 | Linksys Wireless-G WRT54G Router
I have a Big Disk Extreme 2TB external hard drive, in fact I have 2 and one of them just started to give me some problem yesterday after one year of use... all of a sudden my computer doesn't see it...
Apparently one of the disks in the BigDisk array went bad.
If you had the unit configured as RAID 1, you may be able to get your data back by removing whichever of the two internal drives is faulty (just disconnect the internal power supply cable). The unit will boot in failure mode, but the data should be accessible.
If you had the unit configured as RAID 0... that's trouble. Most technical services (and many Linux enthusiasts) will be able to recover half of the data on the unit, the half residing on the intact internal drive. The other half, the data on the faulty internal drive, might be lost or very expensive to recover (there are services which will attempt to do that, but they're SO not cheap).
If you had an up-to-date backup, determine which of the two internal disks is faulty - unplug them one at a time and boot the unit; the faulty disk will likely boot with clicks and clatter; then unscrew it and purchase another of the same model (check the DIP switches and/or jumpers for EIDE models, and configure the new unit same way as the old). Reformat the unit and put back on it the backed-up data.
Jan 03, 2010 | Computers & Internet
Software lost
You can download Sony USB Driver for Microsoft Windows here for Sony DCR-TRV460E camera.
If you require software CD, its available at Sony Accessories and price is approx $12 Just provide CD part number in search box as follows..
3-087-821-01 .... or.... 3-086-790-01
Regards,
Sep 12, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Format Error code C:13:01
this camera is a gem! try finalizing the disc using nero burning software or any alternative. but dont try this on the disc that has your important pictures for safety reasons.
Jul 18, 2008 | Sony Mavica MVC-FD200 Digital Camera
Catalyst ws-c2926 password recovery problem
  1. Attach a terminal or PC with terminal emulation to the console port of the switch. Use the following terminal settings:
    9600 baud rate
    No parity
    8 data bits
    No stop bit
  2. Unplug the power cable.
  3. Hold down the mode button while reconnecting the power cord to the switch. You can release the mode button a second or two after the LED above port 1x is no longer illuminated.
    The following instructions appear:
    The system has been interrupted prior to initializing the flash file system.
    The following commands will initialize the flash file system, and finish loading
    the operating system software:
    flash_init
    load_helper
    boot
  4. Type flash_init.
  5. Type load_helper.
  6. Type dir flash:. The switch file system is displayed:
    Directory of flash:
    2 -rwx 843947 Mar 01 1993 00:02:18 C2900XL-h-mz-112.8-SA
    4 drwx 3776 Mar 01 1993 01:23:24 html
    66 -rwx 130 Jan 01 1970 00:01:19 env_vars
    68 -rwx 1296 Mar 01 1993 06:55:51 config.text
    1728000 bytes total (456704 bytes free)
  7. Type rename flash:config.text flash:config.old to rename the configuration file. This file contains the password definition.
  8. Type boot to boot the system.
  9. Enter N at the prompt to start the Setup program, Continue with the configuration dialog? [yes/no] : N
  10. At the switch prompt type en to turn on enable mode.
  11. Type rename flash:config.old flash:config.text to rename the configuration file with its original name.
  12. Copy the configuration file into memory: Switch# copy flash:config.text system:running-config
    Source filename [config.text]? (press Return)
    Destination filename [running-config]? (press Return)
    The configuration file is now reloaded.
  13. Change the password: switch#configure terminal
    switch(config)#enable password Cisco
    switch#control/Z
  14. Write the running configuration to the configuration file:
    switch(config)#write memory
Jun 07, 2008 | Cisco Catalyst 2926 (WS-C2926) Networking...
If you can find software to read UDF (universal disk format) you may be able to recover your pix. Whatever you do -- DO NOT reinitialize or finalize the disk. Your existing pix will certainly be lost if you do.
Sep 25, 2006 | Sony Mavica MVC-CD500 Digital Camera
Saitek Aviator AV8R Joystick Logo
47 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
