I have a Toshiba Satellite M105-S3041 and the clock will stop when I shut down my computer, As I researched about my problem, if the clock was set to the default (12:00 AM) ,CMOS battery would have to be changed, but now what is the suitable solution for my case? any help would be greatly appreciated Thanks, Maryam
  • rez1824 Apr 10, 2011
    Thanks for your reply
    You mean I should replace the new battery? if YES, I was told
    this solution is suitable for the case that clock was reset to 12:00 AM (Default setting) . but my clock works and when the computer is turned off it stops working.
  • 32,281 Answers
This problem could be a flat BIOS battery.
Replace the BIOS battery and then go to the BIOS configuration and set the Date and time etc.
Posted on Apr 09, 2011
  • Chris Hingee
    Chris Hingee Apr 11, 2011
    YES,
    When you boot up the laptop and change the Date and Time, the computer will keep the correct time until it is powered off. The good BIOS battery keeps the RTC (real time clock) and the BIOS settings from being lost. A flat BIOS battery erase the BIOS settings.
Closed and shut down my Toshiba Satellite® M105-S3041 PC Notebook, now the power comes on, the fan turns on, the cd-rom begins to boot...then nothing else happens screen stays blank. I have...
I think you should replace it. But if you can't or don't want to you don't have to. I think it haves a power reverse in it and it got hit or damaged from electricity. That could make your computer send files and things like that. It can send them to you, The internet, and even on a near by computers screen. try repair.
Aug 07, 2010 | Toshiba Satellite M105-S3041Notebook
Where do I add memory to my Toshiba Satellite M105-S3041
There is a panel on the bottom of your laptop, with a Philips screw head andv the number "4" in a circle. Remove this screw, and the panel. Under this panel is the memory module(s), and they will take up to 1GB per module.
Oct 03, 2009 | Toshiba Satellite M105-S3041Notebook
Toshiba Satellite M105-S3041 clock problem
Chances are your CMOS battery is dead, it can be replaced inexpensively if you do it yourself. After taking the laptop apart, locate the battery, it looks like a large watch battery. When you remove it, note the battery type and run to your nearest battery store for a replacement.
Jul 07, 2009 | Toshiba Satellite M105-S3004 Notebook
Looking for the New battery
There are really only two things to do. First, look into a replacement battery. A search on Google of "Satellite m105 battery" usually yields one or two sources of after-market batteries for around $50.
The second is only if your battery is a NiMH (nickel metal hydride) battery. In that case, you can create a power profile in the power or toshiba controls control panels where the computer does not go into hibernation or sleep. Go into the bios and make sure that the computer will not shut down on low power, and you may want to turn off the low power alarm. Then, making sure the computer is not plugged into the AC adapter, let it run until it actually shuts down from draining the battery. Then, don't leave it that way, get it back to a full charge. From then on, if you are working with the computer plugged into AC power from a wall socket, take the battery out.
A good source of info, though it's mainly about NiCd batteries, is: http://www.batteryuniversity.com/
Feb 02, 2009 | Toshiba Satellite M105-S3041Notebook
My laptop toshiba satellite m105-s3041 cant running well because not sound device or soundcard detectif. can u tell me why?
first, you go in the BIOS setup..check if the soundcard is disable or not...if disable try to enable and boot to the windows..if its already enable but still not working, check the sound card driver at www.toshiba.com and download driver for sound of your laptop....
Dec 18, 2008 | Toshiba Satellite M105-S3041Notebook
I have a Toshiba M105-S3041. Does it have bluetooth.
first.you need at least bluetooth usb card to activate the built-in bluetooth located somewhere in front edge of your laptop
Nov 13, 2008 | Toshiba Satellite M105-S3041Notebook
Media player buttons
Unistall the software that control the buttons and reinstall
Nov 13, 2007 | Toshiba Satellite M105-S3004 Notebook
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
