Question about Rockford Fosgate Punch 301S Car Audio Amplifier
My amp will only turn on if the remote wire is connected to the remote and also touching the power terminal but if you do it like that then it wont shut off when you turn the car off please help
  • 1,591 Answers
The remote wire is meant to turn on the amp when it gets power.
Normally this is supplied by the REMOTE output on your AM/FM/CD/DVD dash device.
If the output on your car stereo is no longer providing power to the remote switch output, look for other things that only have power when the car is on.
The currend draw to the amp from the remote line is miniscule, and you can pretty much meter the fuse panel for things that only have power when the key is in the ACC or ON position, such as the in dash radio power line or some other suitable line.
Ideally you'll want something that supplies 12V in the ACC, and ON positions of the key, but not in the OFF position of the key.
Posted on Apr 09, 2011
I have a brutus bxi 1206d 1200 watts, and the amp is coming on fine not protected. But there is no sound output. u can hear a small feedback rumble when connecting the input rca's. But thats it. My...
i would check the speaker cables to see if something came disconnected first maybe wire i touching other terminal shorted out the channels output .
run a new set of rca cable to see if one use are bad . check to see if rca cables pluged into right output of radio . check to see if your remote wire is powering up the amp to turn on the amp ..
will still light up with battery power but will never put output to the speakers with out the remote turn from the radio ... how to check this is to disconnect the cable at the amp and take a short 18 gauge wire and strip both ends and touch the battery terminal at the amp terminal one end the other end where the remote wire is mounted on the amp if do this for a few seconds to see what happens or better yet buy a digital volt meter and check for 12volt a the remote wire when you turn on your radio
Dec 23, 2010 | Hifonics Brutus BXi 1206D Car Audio...
When i put on power protect light come on
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible causes, do the following. Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still shuts down (goes into protect mode), the amp almost certainly has shorted output transistors and will need to be repaired. If the amp only shuts down when it's driven to relatively high volume, you need to confirm that you have sufficient power supply voltage. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts on either the B+ or remote line, you need to check the wiring feeding whichever line is too low. If 'both' the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
Dec 15, 2010 | JBL BP1200.1 Car Audio Amplifier
Light on remote wont turn on and it is connected to the amplifier
neg terminal to ground, positivew terminal to 12volt and jump a wire from posiitve to remote wire on amp to see if it turns on
Apr 25, 2010 | Polk Audio PA250.2 Car Audio Amplifier
My kenwood amp wont turn on all the way i just hooked it up to my truck. the blue lights and the fan come on but the red light wont come on to power my subs
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL DOES NOT POWER UP, VERIFY THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN TRY AGAIN. IF STILL NOT POWERED UP, MEASURE THE REMOTE WIRE VOLTAGE TO INSURE THAT IT IS NOT LOWER THAN 11 VOLTS. IF YOU CANNOT MEASURE IT, THEN DISCONNECT THE REMOTE LEAD FROM THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER WIRE FROM THE POSITIVE POWER TERMINAL TO THE AMPS REMOTE TERMINAL WHICH WILL FORCE IT TO TURN ON. IF IS STILL DOES NOT POWER UP, THEN IT WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 20, 2009 | Kenwood KAC-7203 Car Amp
I just bought a Kenwood KDC-X493 and installed it in my Alero. I hooked it up to an amp and a sub and it only works with the tuner and not and Ipod or an auxilary hookup or even a cd. what is wrong.
Hello jarhead455,
It sounds like the remote terminal on your sub amp is not properly connected. The KDC-X493 has a wire to turn on a remote amp (Blue/White) and a wire for a power antenna (Blue). If the blue wire is connected to the amp remote terminal, the amp will only turn on when the tuner source on the receiver is selected. If the correct wire is connected, the problem is most likely in the receiver.
If the receiver is at fault, not under warranty, and you still want to use it, you can connect any fused 12V+ to the amp remote terminal. A simple way is to jumper a short wire between the power and remote terminals. Wire the jumper through a SPST switch conveniently located so that you can turn it ON and OFF as desired.
Hope this helps.
Jul 02, 2009 | Sony Car Audio & Video
Amp not turning on
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If neither is too low, the power supply in the amp is probably blown.
Nov 10, 2008 | Rockford Fosgate Punch 301M Car Audio...
After connecting my Sony XM-1252GTR Car Audio Amplifier it won't turn on
Hi. You should be able to turn the amp on by touching the remote wire to the B+ main power terminal. this will tell you if it is a problem with the remote from your head unit.
Mark
Oct 21, 2008 | Sony XM-1252GTR Car Audio Amplifier
No idea!!
Have you checked the on-board fuses on the amp?
Have you confirmed, with a multimeter, that you have B+ and remote voltage AND a good ground? If not, do the following.
Sep 28, 2008 | Bazooka (EL10190PP) Car Audio Amplifier
Car amp wont turn on
I'll assume that you've checked the amplifier's on-board fuses.
Jul 29, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My kenwood kac7201 amp wont turn on but it has power to it
Recheck the voltage precisely like this:
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 22, 2008 | Kenwood KAC-7201 Car Audio Amplifier
Rockford Fosgate Punch 301S Car Audio Amplifier Logo
83 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
