Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
My icemaker is not working. - Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
  • Maytag Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Often when ice makers slow production or stop making ice it is because the freezer compartmet\nt has warmed up above 17 Def F and the ice maker thermostat will not cycle to start the ice harvest cycle.
In the back of your unit you will have an inlet water valve assembly that will look similar to this one:
Water Dispenser Not Working Check the water supply to the water inlet valve. Check the water filter. ( if applicable)
Check the water inlet valve
Make sure the Temperatures in the Fresh? food section and the freezer sections are normal. 33 to 42 in the Fresh Food section and 0 to 10 in the freezer. Or check that the controls, both the fresh food and freezer section controls are set on the "normal" settings. If the controls are set too cold it will cause the water? tank or tubing to freeze.
Dispenser switch not? working, check for continuity
One side of this valve does the water in the door, the other the water for the ice maker
Disregard any reference to water in door if your unit does not have that capability and there will only be ONE solenoid on the inlet water valve assembly.
If the solenoid coil fails it will not open the water source to supply water to the ice maker. This solenoid is only energized for 8 to 10 seconds as the ice maker sweep fingers (Called ejector blades in the manual) reach the 10 - 11 o'clock position during the harvest cycle. All you will hear is a minor buzz and maybe a minor thump of the plastic water line but the ice maker fills during the last 40 % of the harvest cycle.
Here is a manual you can use for troubleshooting:
Kitchenaid-Estate%20Appliances/Refrigerator/In%20Door%20Ice%20Manual%20with%20Diagram.pdf">http://www.affordableappliance.com/Download%20Folder/Whirlpool-Roper-Kitchenaid-Estate%20Appliances/Refrigerator/In%20Door%20Ice%20Manual%20with%20Diagram.pdf
Note the requirements to test the ice maker using the manual above are:
Door light switch plunger depressed (Taped down) and the freezer temp from 0 - 10 deg F.
You will need to make a jumper wire to jumper terminals T to H inside the ice maker front cover to start the ice maker test. If it cycles with the jumper the thermostat is good. If it does not cycle then either the thermostat has failed or... there is no power coming from the door light switch. (Bad door switch)
If all of the system tests pass and you still do not have water.... suspect the inlet water valve (pictured above) or the water supply as the source of the problem.
More often than not.... the real problem turns out to be ice build up on the evaporator coils due to an automatic defrosting problem. Should you discover a build up of ice on your evaporator coils do a MANUAL defrost session by unplugging the unit and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so be ready!) After the manual defrosting return the unit to normal service. You should have ice again within 12 hours. Keep an eye on the evaporator coils for the next 5 days because if you do have an automatic defrosting problem the symptom WILL return in a matter of 2 - 4 days. If the ice block returns.... have the automatic defrosting problem corrected to keep your ice maker working normally.
Thanks for choosing FixYa,
Kelly
Posted on Apr 09, 2011
Replaced icemaker and optics but icemaker still does not work.
Are you getting water to the valve and the valve is OK. It copuld be water has frozen in the fill tube to the icemaker.
Sep 11, 2014 | Refrigerators
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
Ice maker has stopped working
IT is either your inlet valve which is cheaper than replacing the icemaker, when you replace it(located behind panel on back of fridge) make sure you do not have ice build-up in the water tube behind icemaker. If that does not work than you will have to replace icemaker. If you take a flathead screwdriver and pop the cover off of your icemaker you will either have a screw that you can manually turn to test the icemaker to see if it is working. There is one you can do this with, the other one you would need an icemaker tester that most tech's have. Good luck!
Aug 20, 2010 | Frigidaire Refrigerators
The icemaker will not work
you might need to replace the icemaker or the freezer isnt getting cold enough for the icemaker to operate correctly. if freezer isnt getting cold enought for icemaker to operate correctly you should probably have it checked by a tech. if the icemaker isnt taking water you also could have a bad water valve
Sep 17, 2009 | Refrigerators
Amana side by side icemaker stopped working
The icemaker is not working because the water pressure is too low. An icemaker is controlled by a timer so it has no idea how much water is in it. The water valve gets energized for about 7 seconds letting water in the icemaker, but if there is no water pressure then the icemaker will not fill.
Sep 12, 2009 | Refrigerators
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If it freezes and doesn't dump , replace the icemaker . Make sure the coils are clean of dust , lint , etc .. for refrig to be proper temp for icemaker to work (5 degrees) .
Aug 13, 2009 | GE Refrigerators
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
There is water to icemaker but it does not make ice.
Check if the icemaker inlet valve is opening and if the icemaker solenoid is working.
If the icemaker has a filter also replace the filter.
May 22, 2009 | Refrigerators
Icemaker doesn't make ice
If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
393 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
