Question about Garden
Briggs and Stratton 20hp Intek Twin V OHV engine is not charging the battery on my John Deere L120 mower I have a good digital multimeter. how do I check to see what is wrong or do I just replace "the alternator" Where is it? Is it easy to replace. It also has a regulator. What does that do?
  • 3,740 Answers
Here are the alternator wiring diagrams for Briggs and Stratton Engines:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/alternator_replacement%20with%20wiring%20diagrhams.pdf
Most alternators have an AC output but others that have an in line diode will have an AC reading BEFORE the diode and a DC reading AFTER the diode.
If you going to check alternator coil resistance you must check resistance before the outgoing in line diode connection (alternator side.)
When you check a diode you will read ZERO resistance with the meter leads in one direction but infinity when the leads are reversed probing the same two test points. Any other resistance reading = bad diode.
You may have an AC output and a bad diode from your alternator. Check the resistance of the alternator stator winding on the alternator side of the diode. You should get a reading under 500 Ohms. If you get infinty the alternator has failed.
Kelly
Posted on Apr 11, 2011
Have a John Deere lawn tractor with 20HP Briggs V Twin. Engine ran great four 4 years (200hrs.) then started having fuel problem. Changed filter didn't help, changed fuel pump didn't help, cleaned...
You could try sending your question to the Customer service on the Briggs & Stratton Website. Maybe they will be able to explain and suggest a good solution.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs 20 hp intek , it run about 15 or 20 minutes and shuts down. i've cleaned the carb replaced filter and fuel line and replaced both coils . what is making my filter run dry?
Believe it or not, I had this same thing happening on our L120 John Deere. Turned out to be a plugged gas cap vent! At first I couldn't believe it but i resolved it with my air compressor. Now I always make sure the vent is clean and have had no problems since.
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
912 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
