Question about Stanley Bostitch Coil Framing Nailer
I hav a coil nailer the problem coming is it fires double nail right after one blank shot , i hav tried everything by replacing its all types of O rings also changed the piston but the problem still persists . Can anyone pls suggest me what should i do.....
    President:
  • Stanley Master
  • 1,383 Answers
Remove nails from the canister and test fire the gun very rapidly with side door open against hard rubber (old tire or coiled up rubber hose ) to absorb the energy. Look for driver and feeder to move in time together and driver should return to top each time. If feeder appears to lag behind, check feeder orings and air passage to feeder piston. If driver appears to come out out nose too far or if it does not go back to top every time suspect problem with bumper or cylinder check seal. Look at feed check built into the side door. These must make contact with nails to prevent miss fire. If all appears to look normal, replace the TVA6 valve if the firing pin fits/feels loose in body of the valve. Miss fire occurs when nail checks do not hold nails in place (feed checks on door and feed piston) and or the piston does not go all the way back up so the nail can not feed into place. Less often, miss fire is caused by lower bumper missing pieces /cracking and the crumbeling bumper pieces enter the feed piston chamber preventing the feeder from making full travel forward. One more area to check is the head /headvalve. Remove head and pull out headvalve. Remove fine scratches on surface of head where orings make contact (use 400 grit paper) and lube with silicone paste lube (sold at Lowes in the plumbing department). Finally check the cylinder seal sitting on top of the cylinder. It should fit very snugly against the cylinder and not turn. If it can be turned, replace with new or remove and apply RTV sealant and replace, then wait 24 hours before use. Good luck
Posted on Apr 09, 2011
My NT65AB is double firing every 4th to 8th fire, is there an adjustment on the trigger?
Chris, you will have to check your manual to see if your make and model has adjustment. Double fire is normally caused by one of three things,
1. The nailer is not being held down with enough pressure when the gun is fired.
2. Triggers valve is leaking and not releasing fast enough for a single shot.
3. The pressure fire feature on the nose of the gun (if applicable) is faulty.
If adding pressure does not help, then it is most likely faulty trigger, replace it. For guns that use a press-and-fire system, the spring in the nose of the gun may be worn, causing the double fire of nails.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Diagnose Power Air Nailers
nailer double nailing
http://www.mastertoolrepair.com/images/How%20to%20Repair%20you%20Nailer.pdf
May 23, 2016 | Air Tools & Compressors
New nailer double firing and jaming
Some trigger valves (tva6) are sensitive (defective?) however there are some things you can try to change how the gun acts. I have noticed that the brand of oil has an effect on the orings. Some brands will swell the orings, I like Paslode nail gun oil. Do not wash the gun with gasoline or wd40. Use diesel. Change the nail depth setting one position. Lowering the air pressure will make a difference. I find that most operators use too much pressure. A stronger safety spring under the trigger will separate the trigger and firing pin quicker. Finally you could use single fire trigger. Good luck
Jan 16, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Www.dewalt.com
Worn trigger valve orings will cause gun to fire twice, and /or attempting to single fire nail with bump-fire trigger. Easy test, look closely at firing pin under trigger. It should fit snuggly an not move from side to side in valve. If loose, replace valve. If your nailer has bump-fire trigger, do no attempt to place gun then fire one shot because the gun will most likely double fire. Good luck.
Oct 09, 2012 | Porter Cable Coil Roofing Nailer
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
NR90AE Nails jammed how to remove
New user will jam the gun/ nails because gun was most likely not bump fired. Placing the gun then depressing trigger will usually cause double fire in the hands of new user. New user should practice on scrap lumber bump firing at many angles till they get the idea; or give them a training period with a nailer that has a single shot trigger (they may develop bad habits with single shot however).
Nov 14, 2011 | Hitachi NR90AE Full Round Head Framing...
I changed the feeder springs in my hitachi NV83 a2 and it wants to double fire and jaming up the driver with seconded nail. it was skip nailing before i changed springs. any help you could give me would be...
Your nailer is a very heavy duty nailer with very powerful blow. Works best with full size nails, not 2 inch range that are used in fencing, they are not spaced correctly for your gun (like hitting number 6 nail with sledge hammer). Open side door and remove the nails, leave the door open and dry fire gun against piece of rubber or old coiled air hose. The driver should return all the way up between shots and the feeder should move back then forward just as fast as the driver moves. If the feeder seems to move in slower motion then pull feed piston and replace orings and remove debris from feed cylinder. If the driver seems to stick out further than normal then lower bumper could be breaking up causing debris to enter feeder. Make sure that the driver is not bent and has a squared bottom, if rounded, remove and grind square. Finally adjust the depth control up or down slightly and bump fire for test, do not place gun on the work then fire. good luck
Jun 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
How do you set up the bostitch coil framing nailer for contact nailing?
Bostitch nailers have two triggers available. Black trigger is rapid fire while the gray is single shot. Both triggers are usefull depending on type of work. Most people say that there is a degree of accuracy with single shot allowing for better placement of nail. If speed is your goal then use the black trigger to bump fire. More information and parts can be found at www.bostitch.com , look for "Support" tab, then "service / parts " find your model number from the pull-down list and search for the manual and parts list for needs. Good luck on your projects.
Jun 30, 2010 | Stanley Air Tools & Compressors
My bostitch rn46 seems to double or triple shoot nails frequently. Am I not using the tool properly or could there be a mechanical problem with the tool?
if u are right nails for gun,then make sure when u put coil in and feed in front of firing pin the nails are straight with pin and connecting wires are not bent causing nails to fall out of alingnment.
Oct 02, 2009 | Stanley Factory Reconditioned Bostitch...
It will double fire sinking second nail only half way. This happens every third or fourth shot. The nailer is a Hitachi NR 83A 3.25in. X .131
the pin pushing your nails is loose and the guides are warned .
try to change the guides and you will see that this problem will will be gone .
one last thing , make sure the coils are in good shape as it may create some feeding problems and push 2 nails at once
Sep 26, 2009 | Hitachi VH650 2 1/2" Full Head Fencing...
Max 890s coil nailer does not advance nails when operated.
Make sure you have at least 100 psi available and I would pretty much drown the sliders and other moving parts in something like Marvel Mystery Oil.
Feb 26, 2009 | Mx Max Cn890s Coil Nailer O`ring Parts Kit
Stanley Bostitch Coil Framing Nailer Logo
180 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
