Vpl-cs2 Projector boots up and displays "S-Video" as the input. It will not let me change the input. In fact none of the buttons on the machine (or remote) seem to do anything. The projector worked perfectly fine but has been stored the past few years without use...
  • 442 Answers
Remove all input signal connections.
Cover with a cardboard box to keep stray flourescent light off the IR sensors.
see if it starts up as before.
Posted on Apr 11, 2011
Ive recently bought a second hand Sony Cineza VPL-HS2 projector and it doesnt have an AVG input in the back. It does have a S-Video input, a 'video' input and a couple of audio inputs,
I think you mean "VGA" not "AVG". You can use the VGA to S-Video adapter to connect the laptop to the projector however you may get better results using a VGA to A/V (component) adapter to feed video into the RCA video input connector.
Nov 20, 2014 | Sony Cineza VPL HS2 Multimedia Projector
I connect new LG Blu -Ray On my Sony Cineza Projector.but only blue colour on the screen ,what is the problem here?
You might have to change the input or start playing blu-ray disc and then change input via the remote to your projector. Make sure it's HDMI out on blu-ray if choice is given and HDMI in on projector.
Jul 10, 2012 | Sony VPL-HS51A / VPL-HS60 Multimedia...
I have a Hitachi CP-L500 LCD projector. It is connected to my laptop from the svga projector port to the svga port on the the laptop. It is making no signal connection. I have made sure the input button...
I am not familiar with your Hitachi LCD projector . However , I do have a little knowledge regarding video signals and inputs / outputs as well as connections . If your connecting cable is one piece (has no adapters added to either end of it ) I would believe your problem is simply a settings misconfiguration in your projector / computer , or both . First , access your startup BIOS / CMOS settings during the initial booting sequence in your computer by pressing F1 or whichever keys you press when you turn the computer on to access it . Then , in the advanced list , check your primary video input selection to be sure it is default. Then, once the computer is completely booted and you can click on your start selection , go to your video settings and check how to switch between internal and external display options . I say this because it is important that you are able to reroute your video signal to your SVGA Out from the laptop (for sure) and it is in fact in that video output mode. Once you're sure you have a signal going out of laptop through that port , go to your projector video input selections menu and select each and every input option available until the signal comes through . This will only work if you're absolutely 100% sure that your video signal is in fact leaving the laptop via the SVGA port connection .
Sep 05, 2010 | Computers & Internet
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Focus
Hi mwwill
Try using a different cable from your source.
If this doesn't solve the problem I would advise you to rather take it to a repairer as this could be either the lens that is damaged or the Mainboard where all the processing is done.
May 13, 2008 | Sony VPL CS2 Multimedia Projector
Panasonic PT-L501U
Hi BEEZELLE
Does the VGA input work ?
If not then the Mainboard is at fault and will need either repair or replacement.
May 11, 2008 | Sony VPL PX31 Multimedia Projector
Power up
Hi mick1907
Take out your lamp and check for any irregularity like marks or discolouration.
If there is no visible damage - put back the lamp and take of the top cover - start the Projector and check if all your fans are running - that is if the machine starts at all.
If the unit doesn't start up at all you will have to replace the Mainboard.
Apr 24, 2008 | Sony VPL CS2 Multimedia Projector
Getting image to project
You are going to have to read the manual, and operate the projector as you read each section
Oct 16, 2007 | Sony VPL CS2 Multimedia Projector
Sony VPL - ES2 Colour problem
Isolate problem by using video and data(PC),if none of the imputs work call the vendor or Sony and sent it back for repair.
Aug 31, 2006 | Sony VPL-ES2 Multimedia Projector
43 people viewed this question
k24674
jasbo
jasbo
