Bought Sylvania LC220SL1 without manual or remote and do not know how to set the channel to work with comcast cable. Comcast provides a cable box and its own remote.
4 Suggested Answers
SOURCE: Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
Posted on Aug 20, 2009
  • 10 Answers
SOURCE: comcast remote code for sylvania
I have the same problem. I found that there are many Comcast remotes by the way.
I called Comcast and they had no clue. But I called Sylvania and their reps were FABULOUS!!! Turns out, the TV makers send the cable companies the frequencies for each TV then the cable companies send them to a 3rd party to get the codes written.
This model of TV is new and there is no code written. The rep suggested that we countinue to check back on the Comcast website regularly to see if the code is posted. She said that the sales reps tend to get the info last.
The Sylvania rep anticipates a new code written soon because this is such a prevelant problem.
Posted on Dec 20, 2009
  • 5 Answers
SOURCE: can't get my hannspree remote to work with comcast
My Comcast Motorola STB's (Set Top Box) DCT 3412 / 6412 remotes did not support the new Hannspree 28" TV remote codes. Then I discovered the Hannspree TV remote was universal and had a button for Cable. Holding down the Cable buton I programmed in the Motorola VCR code 0050 and now my Hannspree remote controls the Comcast STB. Now I use the TV remote to control both Comcast Ste Top Box. PeterC
Posted on Jun 13, 2010
I have comcast cable. i need the 5 digit code for the remote.
here is a link to all comcast remote controls and there manuals. Code will be in the manual
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Oct 17, 2010 | Sylvania LC370SL8 37 in. LCD Television
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
I need a remote code for my RCA TV . Comcast Cable provided a remote for their digital adapter and was told to enter one of the RCA codes. None would work. Comcast and RCA told me to use both remotes which...
your rca does it have a button for cable. then you can program your tv remote to work with the cable box. go to the manual and try all the codes for rca tv. if this does not work then you have to try it manually. have them give you a different adapter. it might be in the box or remote.
Feb 09, 2010 | Televison & Video
MOTOROLA DCH-3416 FOR COMCAST: will it work if i buy one ..
no it will not work. It will have to be set up and flashed by comcast, so there is no way to use it with out them knowing it.
May 09, 2009 | Televison & Video
Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Mar 01, 2009 | RCA RCR450 Remote Control
Took toshiba off comcast control and now ct-90157 won't work
We found the manual at home and was able to program the t.v. to recognize all the channels from cable and store them.
Jan 26, 2009 | Toshiba CT-90157 Remote Control
Figuring out the TV channels for Comcast using the Sharp remote
Unfortunately there is no listing. I suggest taking a little time to sit next to the television with an notepad to go through each channel one at a time to label what stations come in on what channel numbers. Sorry.
Jan 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Comcast Universal Remote code for Sylvania LC370SL8
Call your cable provider they may have a serch code that you can use to auto serch for the code
Feb 21, 2008 | Sylvania LC370SL8 37 in. LCD Television
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
