Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman dlt 2000 starts and runs good, If I turn it off it starts and dies after 5 seconds, using the choke does nothing for it. Does the same thing at any throttle speed. Once it cools, it starts and runs until I turn it off again and the problem returns. Thought maybe it was vapor lock in the fuel pump or maybe a coil going to ground but if it was a coil I would think it would ground out during the run. Need a little help.
  • 3,740 Answers
This appears to be all fuel related. The repair would depend on which engine you have. 1 being the CV624S Kohler and the other being one of several Briggs and Stratton Engine ranging from from 16.5 Hp - 25 Hp.
What I suspect is happening is that there is possibly debris in the very bottom of the float fuel bowl. When it sits for a while there is enough fuel that has made it by the debris that the engine will start. The fact that the engine is running creates enough vibration to float the debris away from the fuel passages. Regardless of the brand of engine you have remove the float fuel bowl and remove the debris. Then take some carb cleaner and tidy things up.
I am pretty sure the engine has a fuel shut off solenoid in the base of the carb float fuel bowl. When you remove this to gain access to the float bowl... take a look at the plunger on the solenoid. Make sure it moves up and down freely. Any sticking / spalling can cause big time engine run or starting problems. This solenoid is energized to the retracted position when you are in any engine run or start configuration. If this solenoid never retracts your engine will never have any fuel to run and chocking it will make no difference because the solenoid is blocking the fuel flow into the carb throat via the pick up tube in the bottom of the carb.
IF after you have cleaned the fuel float bowl out you still have hot start issues. It is time to start chasing wires from under the flywheel to the throttle control, to the seat switch, the blade engage foot switch and in the bnattery area. You looking for any signs of a hot wire. Frayed strands of wire at any terminal lugs or unusual corrosion. This must include the ignition switch. Take areally hard look at wires to the low oil sensor and make sure they are not chaffed. To eliminate the low oil sensor as a suspected problem FOR TROUBLESHOOTING ONLY disconnect ONE wire from the low oil level sensor then see if it starts. If the symtom is gone... dirty or bad low oil level sensor. If the symptom persists look hard at any engine wire to make sure that when the insulation gets hot that it is not causing a ground.
Let me know how it goes. If you still need more assistance I really need the mower model number (For chassis wiring) and the Engine model number for engine wiring and fuel systems so I can better assist you.
One more oh by the way question: Is there SPARK when the engine is hot and will not start? No Spark = not a fuel problem at all.
Thanks for choosing FixYa,
Kelly
Posted on Apr 09, 2011
  • Kelly
    Kelly Apr 10, 2011
    I had another line of thought of what might be causing this. Check the OIL level. If the oil level is at the low level; starting the engine could cause enough crankcase cavitation to cause the low oil level sensor to ground the engine. I really can help you and can provide service manuals.... I just need to know your Mower model number AND your ENGINE number so I can pass you the correct manuals.
    Kelly
Craftsman DLT 2000 with Briggs and Stratton 25 HP. Engine runs at wide open throttle.
What is the float set at? What about the jets and fuel screw? Do you know what the fuel pressure is?
Aug 26, 2016 | Craftsman Garden
Craftsman dlt 3000 16.5 honda engine will only run if the choke is closed
if it still won't run after cleaning the bowl...you will need to remove the small jet inside the bowl that allows vaporized gas to be pumped into the carb..it is very small you will need a needle or something similar to clear..it usualy is next to the bowl float and is vertical to the carb..good luck
May 31, 2012 | Garden
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower dies when put in gear
have you checked the mower bed to see if its free to turn over,,if the bearings have sezed up or are tight this loads up the mower engine
Jul 05, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman DLT 3000 18.5HP - Engine Dies
sounds like the choke mechanism is stuck in closed position, causing a overly rich mixture, to check this removethe air filter cover, element and housing, there are two nuts and a 5/16 head screw somewhere that need to come off too, then pull off housing and you will be able to see the choke plate, it should only be closed when throttle lever is all the way up. when you determine if this is the pronlem or not you can email me if you want
thisoldtruck2@yahoo.com
May 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Last time I STARTED MY VSTAR 1100 I CHOKED IT FOR 10 SECONDS ON HIGH THEN MOVED TO MEDIUM CHOKE FOR 4 THEN TOOK OFF AT NO CHOKE. 2 WEEKS LATER. I started up bike Choke on high bike barely wanted to idle...
Sounds like your flooding it out with the choke out. Try the next time you go to start the bike when it's cold with the choke out and when it starts push the choke all the way in and keep it running with the throtle. If it runs better after doing this then your flooding it on start up. Use 1/2 choke to start cold and see what it does. Good Luck
Sep 29, 2009 | 2001 Yamaha V Star Classic
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
2000 Oldsmobile Bravada
Please stop using the starting fluid, it is terrible for your engine- use choke cleaner if you need to do this in the future again. you can run it on choke cleaner indefinately if needed.
It sounds like your fuel pump quit on ya. When you turn the key to the "run" position do you hear the pump run in the tank for 3-5 seconds? you should. The fuel pump is in the gas tank and the tank has to be removed to acess it.
you can remove the coil wire from the coil and check to see if the coil is firing a spark. crank the engine with the wire off. make sure there is no starting fluid or choke cleaner fumes around before you do this-k? Carefull not to let it shock you. if it is sparking then you should check the fuel pressure. it should be 60psi while cranking the engine. you will need a fuel pressure guage to do this.
Good luck........Scott
Sep 21, 2008 | 2000 Oldsmobile Bravada
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
533 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
