Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
We borrowed a lincoln arc 225 and welded with it, but when we changed the amp selector switch, it was hard to move then broke free and clicked. When we turned it on after changing amps, no spark. No spark on any settings. We think the switch broke. It still clicks on the settings, but something must be wrong. We were going to get into the welder, but stopped short when we noticed a capacitor. Didn't have any way to discharge it. Are there replacement parts avail for the amp switch? The welder is kind of old. Code 9221-910.
3 Suggested Answers
  • 225 Answers
SOURCE: cooling fan/ lincoln 225 arc welder
the fan should be pulling air from the front of unit and out the back.
Posted on Jun 18, 2009
SOURCE: lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Posted on Sep 06, 2010
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding rod sticking when striking arc
try striking the rod like a match. keep a good arc, not too long or short. try around 90 amps.
Apr 28, 2013 | Lincoln Electric K1170 AC-225 Stick Welder
Welder is not sending strong arc
maybe its your volts too. make sure you are grounded properly and clean from debri's, strike the electrode like a match and keep the arc close to your work-piece. dont go too fast and make sure your not wearing to strong of a lens in your hood. gold lens number 10 are the best for 7018 rods.
Jan 27, 2013 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln electric ac/dc arc welder model ac/dc
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln AC/DC 225 control dials inoperative
the only way you can get a repair manual is to be a service shop,but what your saying is the dial turns with no resistance.did anyone turn the dial while someone was welding?if so the dial has to be replace,what happens is the contacts inside the unit weld together becuase once the dial is turning it breaks contact then makes contact welding the dial in place.You would not be able to turn the dial.so if the dial turns very easy I would check to see if the dial handle is loose on its shaft.the unit can be taken apart but it just takes a little time.it is a very basic unit with not to many internal parts.good luck,you can fix the problem.
Jun 05, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln welding machine
did someone turn the dial while welding?what has happened is the contacts are welded in that postion.I worked on welders for lincoln,hobart,esab and miller as warrenty repair shop.I never was able to dislodge the welded contacts to work smooth agian,you have to buy new dial and probley have tech. put it in.
Mar 13, 2009 | Lincoln AC-225 230V
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
130 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
