Question about Omega Model 02 Juicer
My juicer smells like it's burning and the juice, well part of it, is going into the fiber catcher and very little is going into my cup. Do I need a knew blade?
  • 4 Answers
SOURCE: the juice that comes out
http://www.mypowerjuicer.com/manuals/pj/images/power-juicer-manual.pdf
Posted on Feb 24, 2008
wbecca52
  • 3 Answers
SOURCE: Acme Juicer
Are both of the metal parts that you twist the top onto still sturdy? One of mine is broken, and I have to find a replacement part.
Posted on Mar 06, 2008
  • 6 Answers
SOURCE: problems with juice lady...advice please?
Try foxinternational.com
or call their toll free # at 1-800-233-9054. Note read this first:
Have your model # handy it starts with JL (ours is JL500, but yours may be different--you made need a magnifying glass to read it.) It is on the bottom of the unit, most likely--or, on the side. Hope you can get help there. They have some parts, especially if you are in the United States. (If you are in Canada please note:
Also has depot in Canada-but not all parts available there & they will not ship from the U.S. warehouse to Canada. If you have a relative or friend have them ship it there & have them forward it on to you. Send the S&H $ required to friend or relative...)
Posted on Oct 21, 2008
  • 21 Answers
SOURCE: Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Posted on Mar 14, 2009
SOURCE: rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Posted on Jul 12, 2009
The pulp is quite wet after juicing 2 cups juice. Can you pinpoint the reason?
Let it spin for a 2 or three minutes after juicing. You
can also, slowly, pour a little water down the chute to
leach out more juice and dilute it as well. Also hold
the basket up to the light to see if some of the holes
have become clogged and use a tooth brush to clear
them. If you're using the filters, just rely on the basket
alone, it's not that hard to clean.
Jan 26, 2011 | Acme 6001 Juice Extractor
My juicer moves a lot when juicing
They all vibrate no matter what you do. Best solution, costly, is to get a pulp ejection
type juicer. Miracle MJ1000 is a nice little juicer for about $130.
Nov 04, 2010 | Omega 1000 Juice Extractor
The engine started to make a horrible noise and practically jumped off the counter while it smelled like something burned.
these juicers have a tiny little motor. once they smell bad, they are shot. not worth repairing. Joe
Mar 04, 2010 | Jack Lalanne Power Juicer 250 Watts
When juicing apples, does the skin need to be taken off first?
Hi - I'm not familar with the brand of juicer - but normally you do not have to take the skins off- are the apples fresh?- if the apples are old and flowery you will not get much in the way of juice
Feb 22, 2010 | Lexen GP62 Juicer
How to use
2 cups of water poured into the reservoir. 1/2-1 cup sugar in the sugar chamber-spread evenly. refill pitcher with 2 cups water and ice to ice line. turn on lemonader and juice 4-6 lemons. When unit shut off, stir juice and serve
Jun 15, 2008 | Salton LM8 Lemonader Citrus Juicer
Stop running in the middle of juicing
well this is very common with this version, clean inside out, shredded fruits and veggies tend to stick and jam blades.
Jan 09, 2008 | Jack Lalanne Power Juicer (Stainless...
The reset button
IT'S THE RESET BUTTON AND THEY ARE
ADJUSTABLE. REMOVE 4 SCREWS UNDER
JUICER TO REMOVE BOTTOM. YOU CAN
GET AT THE RESET BUTTON HOUSING AND
ADJUST THE SMALL SCREW EITHER WAY.
YOU WILL HAVE TO FIGURE OUT WHICH
DIRECTION. CLOCKWISE OR COUNTER.
IT YOU GET IT WRONG IT WILL CUT OUT
MORE FREQUENTLY SO JUST GO THE
OTHER WAY.
Oct 06, 2007 | Acme 6001 Juice Extractor
Juicers Logo
121 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
