Question about HP Televison & Video
We have a 42" Hewlett-Packard HD Plasma TV. It's
  • 2 more comments
  • revrichar395 Apr 09, 2011
    I don't have a soldering iron but I could go and buy one. I worked with one many years ago so I do remember how to use one. Where would I get capacitors from? Radio Shack?
    How would I know if the YSUS circuit boards need to be replaced instead of or in addition to capacitors?
    How will I if I need to replace the Ysus circuit board as well?
    ...I know...
  • HP Master
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually the screen may come on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Apr 09, 2011
Testimonial: "Great advice thanks. "
  • 3 more comments
    Where do I get capacitors from? Radio Shack?
  • Norman Skinner
    Norman Skinner Apr 09, 2011
    If you had watched the videos, you would have heard at least one of them mentioning that they got their caps from Radio Shack, but pretty much any electronics shop will have them such as The source by Circuit City etc. or you can order them online.
  • Norman Skinner
    don't forget to follow the guidelines...it's ok to go over-voltage but stick to the right value of capacitance and try to stay close to the same physical size, or you may not be able to get the casings back on.
    I took the back panel off and I can identify the power supply and inverter / FM section but none of the capacitors are bulging or leaking. They all appear to be in great condition. Any ideas on what to look for now?
  • Norman Skinner
    check for fusible links between the power supply and the other boards.
    Pay special attention to any board directly attached to the screen and the board it's cabled to (and check that cable really good too!)http://www.google.ca/images?hl=en&so...
    that link will give you an idea of the different types of surface mount fuses so that you have a better idea of what to look for.
    And remember, the caps may not be completely domed or leaking fluid...look for caps that are even a bit convex!
    Oh, and stop looking in the inverter section if that's actually a plasma TV, because there isn't one....sorry...lol...
    If however it's actually LCD and not plasma, I'd look very closely at the inverter section and fusible links going there.
Cannot get to be a monitor for my pc
check your resolution settings also set the hertz properly, it should be working!
Apr 05, 2013 | RCA Hp Hewlett Packard Plasma Flat Tv 42...
Y Board is out. The boards costs about $150 and easy to install.
Mar 12, 2011 | HP PL4260N 42 in. Plasma HDTV
Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
5 year old plasma that looses half the picture
Hello. I recommend that you forget the repair for two reasons. 1. Pricey. 2. You still have a 5 year old set with no warranty. In the last five years, the tv technology has come so far. The HD is fabulous. The new sets cost less to operate and they are so much better than they were five years ago. Joe
Mar 24, 2010 | Philips 42PF9630A 42 in. Plasma Television
Screen only partial and only shows in red and black
sir/mam the problem of your plasma t.v is the panel,weak panel. i have already encountered that kind of problem.
Aug 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Sounds on but no Picture
check local tv repair shops. better price
Jul 22, 2009 | HP PL4260N 42 in. Plasma HDTV
50 inch samsung plasma that is 3 years old occassionally gets a black bar across top half of the screen. is this tv done?
not necessarily, sometimes the connectors that feed the screen get old and dirty
If you have some electronic skills, open the TV and clean the connectors around where you see the symptoms and you may have a good chance to get if fix by doing that...
good luck
Jul 13, 2009 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Screen has gone blank. Is this common? Fixable?
Contact us to join our group who is taking action for the same issue. dorje@forexcafe.org
Jun 02, 2009 | HP PL4260N 42 in. Plasma HDTV
Horizontal Black Bars on HD channels?
You can change aspect ratio by remote. I hope it will be solve
Apr 02, 2017 | Dell W4201C 42 in. Plasma HDTV
Plasma tv picture went black
I would say you dont need to repalce Servcie kit.kit is only for 42EP24S units.
examine your unit What is the problem?Is the blue indicator on?If indicator on you will have audio.
In this case I would check first Y-sus board or Z-sus board.
Good luck
Dals123
Sep 28, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Televison & Video Logo
520 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
