Question about NORITZ Natural Gas Tankless Water Heater 9.3G/PM
Vibrating when the heater starts to heat water
    Scholar:
  • 73 Answers
Things to Check:
1. incoming gas pressure (minimum 5" when unit firing)
2. Make sure damper on top of unit isn't sticking
3. check vent length and #elbows versus installation manual specs
4. if above 2000', disconnect high elevation termination
If these all check out, you'll probably need to do a manifold adjustment. Call Noritz for assitance on this.
Posted on Apr 29, 2011
Water heater makes loud noise when burner is on
I would check the metal door on the bottom near the burner, sometimes they come loose and vibrate. If not that then I would suspect the chimney liner inside the tank, I have seen them corrode and start vibrating when the gas is running
Jun 09, 2012 | American Standard 40 G Natural Gas Water...
Why does my self cleaning gas water heater make clicking noises?
zdriscoll-
All tank water heaters make some amount noise, clicking and "snapping" sounds, particularly after much of the hot water in tank has been used (like after a long shower) and has been replaced by cold water that is being heated vigorously.
If the noises are accompanied by poor or erratic performance, or obviously if something malfunctions, you may require the services of a repair connection.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
Jul 03, 2010 | Rheem Direct Vent Natural Gas Tankless...
My water heater emits a loud high pitched whistle when it is venting. Any ideas how to correct this?
I have an AquaStar tankless and it has started making that high pitched sound when in use. I wonder if that means I have clean the heat exchanger. I called Bosch but they won't help since it is installed in a bathroom--in violation.
Jun 21, 2010 | Bosch & Tankless LP Hot Water Heater
We just installed a Rheem 50 gallon water heater. When you use any hot water a low pitched vibrations occurs that you can hear in the bathroom and bedroom. When the water heater completes the heating cycle...
Every electric water heater I have ever installed makes a low hum while heating. I believe this is a combination of the current going through the elements and the minerals in the water cooking on the elements. That is the best explanation I have. Hope this helps.
May 11, 2010 | Rheem 81VP6S/430126 Water Heater
We just installed a Rheem 50 gallon water heater. When you use any hot water, a low pitched vibrations occurs that you can hear in the bathroom and bedroom. When the water heater completes the heating...
Listen close near any check valve that may be in the piping system, as well as the pressure relief valve on tank. It may be a check valve rattling, but you normally will only experience that when water is flowing in and out of the system.
Mar 19, 2010 | Rheem 81VP6S/430126 Water Heater
Takagi TK-JR vibrating noise
Remove your hydronic pump and replace the flexible impeller coupling that couples the impeller blades to the pump motor. make sure you don't do this on a sat or, sunday (i hate house calls then) and, be sure you have a new pump housing gasket before you start the job. Also check the unit for loose pipe brackets
May 20, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
When hot water is turned on the pipes make this vibrating sound.
A rumbling more than a vibration? If one in the same, the heating elements may have calcium build up which causes perculation like the perculator coffee pot which causes the heater to vibrate or rumble. If the elements can be removed they can be cleaned by soaking in lime away or a descaling solution. All said and done it will work like new.
May 03, 2009 | Water Heaters
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Dec 31, 2008 | Rheem 81VP6S/430126 Water Heater
NORITZ Natural Gas Tankless Water Heater 9.3G/PM Logo
299 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
