Question about Pioneer DEH-P6700MP CD Player
I got my radio in but when the car is shut off it resets it self it won't hold memory
    Scholar:
  • 83 Answers
Is this a brand new car radio? Usually with this kind of problem its with the IC of the radio itself. Double check your connections at the back 1st, also check the manual. If everything is in order, well its the radio itself.
Posted on Apr 09, 2011
I have a 2005 sts cadillac & the navigation system nor the radio/cd player works, is it a fuse that has blown or some other problem that i am experiencing
yes and no fuse can be bad. if it has back up cam connected to it the back up cam can shut it down pull all 4 fuzes at same time . clock fuze, land nav fuze, radio fuze and backup cam. in my caprice i have to pull clock, radio, and backup cam at same time to reset. clock fuze holds memory for all
Sep 04, 2017 | Cadillac Cars & Trucks
How do i reset a radio to keep memory afte ?r car is shut off
There should be a live feed to the radio when the ignition is off.....this allows the radio to save stations! Check there is a constant live feed to your radio!
Feb 21, 2015 | Rockford Fosgate Car Audio & Video
Audio 50 losing its memory
In the manual, I can see there is a separate entry, for the memory power, But searching why it does not have power, is and perhaps only inside the radio is a bad connection, should be done on the system self.
Feb 03, 2015 | Car Audio & Video
Volvo xc90 radio won't work. reset battery and it works until you shut the car off and then it won't work again.
thers an issue with the convenient/assesory module--get car scanned with pro equipment not at a partsplace
Dec 06, 2012 | 2004 Volvo XC70
Tv shutting off wont let me delete parental code, i dont know what it is
You can reset the parental pass-code.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sep 02, 2012 | RCA TruFlat 27F520T 27" TV
How do you set a radio station to a place?
I would assume that this Jensen should store stations much like other cars. Find the radio station you want, press and Hold the button in until you hear the radio start again. Note- If you installed the radio your self and didn't hook up the power correct, the programed radio stations will be lost when the vehicle is shut off! Hope this helps!
Best Wishes and Good Luck!
May 05, 2011 | Jensen VM9510 Car DVD Player
Stuck on system loading and won,t shut off
  • Try to press and hold the reset botton for 10 seconds then release to power cycle the memory of your gps device.
Feb 09, 2010 | GPS
My 1996 nissan maxima bose system resets its self
you need to pull the radio out and verify that you have 12 volts all the time at the Pink/Blue wire in the radio connector plug, this is the keep alive memory, without this constant 12 volts the radio will reset every time the key is turned off. I assume you have checked the fuses. If the wire is ok and has 12 volts present then the radio is defective and will need to be sent out for repair..
Apr 12, 2009 | 1996 Nissan Maxima
Rino 120 - Disabled WAAS
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
Oct 04, 2008 | Garmin Rino 120 2-Way Radio
Pioneer DEH-P6700MP CD Player Logo
78 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
