Question about Toshiba 53HX71 53" Rear Projection HDTV-Ready Television
My Toshiba 53HX71 takes about 20 minutes to "warm"
  • 4,234 Answers
This is a symptom of poor solder connections inside the set. The set will continue to deteriorate until it won't turn on at all. This is essentially a labor only repair and should not be to expensive for any TV service shop. Once this has been repaired, the set should work for many years to come.
These poor connections are caused by the continual heat/cool cycles because of use and is normal.
Dan
Posted on Apr 09, 2011
  • smptx218 Apr 09, 2011
    Wow Dan! thank you for the quick response! I will get it checked out
Toshiba 53hx71 blinking red light when p83 to p803 is connected
I have a 53hx71 that is haveing an issue with my blue on covergence. I have replaced both the chips and it still wont move up or down when i try to adjust manually and the auto adjust wont work either can anyone help?
Dec 08, 2013 | Toshiba 53HX71 53" Rear Projection...
When you first turn it on, the picture is scrambled. takes fifteen to twenty minutes to warm up and get a good picture. Once and awhile after the picture warms up it will blink like the picture is going...
It seems that your unit has some sort of Thermal fault, either in the main circuitry or the Power Supply Unit, PSU. In all probability it WILL get worse and fail completely.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | Televison & Video
Pfaff 360 automatic slows and stops after only minutes of use
Pfaff 360's don't like to sit, they like to drink. . .. oil.
Set top knob "C" to 0
Right top (zig-zag knob) set to 4, lever below but on the same dial points straight down. Set stitch length to 4. Run 5 minutes medium speed.
After that lift off the top cover and spray inside with "Tri-flow", then run a hairdryer on it for 20 minutes to warm up or set near a warm lamp overnight. Run daily 5-10 minutes and exercise the right knob between 0 and 4 (zig-zag). It should come back to working with oil, time, and heat.
Apr 13, 2009 | PfaFF Creative 7570
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
When initially turned on the picture jumps around for several minutes
"Fonzie-ing it" ? It's terrible that I understood what that meant. lol
Sounds like the tuner has a bad solder joint. You may need a Repairman.
Geno
Jan 24, 2008 | Toshiba 52HMX84 52" Rear Projection...
Toshiba 50VS9UA
Can you assist us in an overbright picture tripping after a few seconds. Toshiba 50VS9UA. Sound Normal
Dec 12, 2007 | Toshiba 53HX71 53" Rear Projection...
Problem with y toshiba 53hx71
Tito,
There is a fairly common problem with those symptoms. Try removing the srs-wow board, stand-up audio board next to the tuner. If the picture clears up it's likely QD01 on the srs-wow board loading down the scl & sda lines. QD01 is an Njm1136d Toshiba p/n# 23009142.
Bill
Dec 01, 2007 | Toshiba 53HX71 53" Rear Projection...
Toshiba 53HX71 53" Rear Projection HDTV-Ready Television Logo
155 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
