Question about Frigidaire FRS26H7 26 Cu. Ft. Side By Side Refrigerator Built in Water / Ice Dispenser
How do I check for continuity? I read this in a solution, but don't know what this is.
  • 126 Answers
Continuity is were u check to see if u have a complete circuit ,to see if u have a break in a wire
Posted on Apr 09, 2011
Testimonial: "Thank ya' much!"
What should i do to pass hydrocarbons inspection
you don`t say if this reading is at idle or during the drive portion of the e-test.hydrocarbons is unburnt fuel which could be even an over rich condition such as too much fuel through the injectors or a bad tps switch,map/af sensor,the car could be running too cool indicating it needs more fuel.you don`t say what the other gas readings where during the test as this can help find the problem even if they fall within acceptable readings.you might want to have this checked out at a shop that knows how to diagnoise emmission problems.
Feb 09, 2012 | 1993 Buick LeSabre
I have 1991 BMW 535 i and my dashboard keep showing this message "brake lining" I don't know what's going on. Also my gas indicator is not giving me the right reading
The "brake lining" means your brake pads( on one axle) have worn to its service minimums and will need to be replaced soon. Have your brakes serviced. continued operation can cause brake rotors to become damaged from metal to metal contact.
The incorrect fuel gauge reading could be caused by several causes, but most likely a worn out fuel level sending unit.
Jul 19, 2011 | 1991 BMW 5 Series
Bright on coming lights cause me not to hardly see anything. On a dark road I cannot hardly see a curve until I'm right on top of it.
I can see either, but I'm old. Don't do this to your NV monocular, it has auto shut-off or dems the gains on the image intensifier tube. Continuing to use NV devises in bright light condition will destroy the image tube. Sorry, I don't know what type of NV monocular devise you have or who manufacture it! Please read the instruction manual. Best, stewbison.
Jul 14, 2011 | Optics
My gas dryer isn't getting hot, I was told it was probably the ignitor, I took a continuity test and got a reading of 80 ohms on my glow plug, I don?t know what a normal reading is for a glow plug....
if the ignitor is lighting or glowing its fine,, what you need to check are the thermostats in the rear of the machine, look here for what they look like and ways to test them
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Jun 14, 2011 | Dryers
My four month old gas dryer is running, but without heat. I reset the breaker, and ensured the venting system is clear. I don't know if I need a repair person or a electrician first. (washer on same...
first off that's an electric dryer with the filter on top so all your parts are in the back of the dryer,unplug the dryer,remove the vent line and the rear panel,on the left you'll see the duct that the lint filter slides into and to the right down low you'll see a white peice with two wires going to it,that's the thermal fuse,when you read any part out with a meter you have to pull at least one wire off to get the correct reading,pull one of the wires off and check it for continuity,if it's open change it out,if it's good move to the right heater box and read out the heater and the thermostat on the box,the dryer is only 4 months old so i don't think it could be filled with lint but the vent line has been there and i would check this out,usually if the thermal fuse or if one of the t-stats go it's usually from bad air movement and over heating.if that vent line is a long run go outside and first make sure nothing is blocking the vent,if there's a screen or cage on it remove it then go back inside and i use a leaf blower to blow out the vent line,just stick it into the vent line that you pulled off the back of the dryer and blow all the lint outside,i've seen birds nest blow out of the vents,hit it with short bursts at first so you don't pop the vent line if the block is real bad and once the air is pushing out you can hit it with 30 second blasts,also you can remove the duct that the lint filter slides into and check it,don't forget to remove the two screws on the top panel to get that out,if you don't clean out the vent line or wherever the block is the part that was bad will keep popping,the part is doing it's job telling you that the dryer is running to hot.good luck and if you need any more help let me know and if you don't have a meter buy one,it will be cheaper than changing out parts that still might be good.
Apr 30, 2011 | Whirlpool TEDX640PQ Dryer
Model 110 73932101 kenmore elite. Blew the circuit board replaced it and checked the relays. Wont heat, found the thermal fuse is blown. Checked the high limit thermostat and the thermistor. Thermistor...
there is thermal fuse, Hi limit, and thermistor. the thermistor should have continuity at room temp I don't know what resistence(ohms) it should have. Most units I have seen provide a schematic and trouble shooting guide taped under the control panel for service personal.
Apr 15, 2011 | Kenmore Dryers
How do i know which wires from the stereo go to the car's wires
Dear sir
if you know how to read a continuity tester then you can check your desire wire . now tester keep it on continuity mode and bring some out your stereo and and check it's wire are going where and start testing continuity one by one it's wire and go forward until the desire place. if you will apply this method then you can know your desire wire.
thank you
hope answer the question
please vote!
Dec 12, 2010 | Kenwood KDC-MP2035 CD Player
How can I determine if my ignitor has gone bad? I had a bad rainstorm and the exhaust vent / tube ingested about 1/4 of a gallon of water. It may have been more, but about 1/4 gallon is what I removed from...
pull the wire connector off and check for continuity,if you get a reading it's good if the 1 stays there on your meter it's bad,also check the sensor and the thermal fuse located on the blower wheel housing,hopefully it will be one of these,we had bad rain here in the boston area and most of the dryers i worked on after were bad motors but if your dryer starts that's a good sign,let me know how you make out
Jul 17, 2010 | Kenmore Dryers
RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
These additional documents may be of help to you:
  1. exploded parts diagram;
  2. parts list.
Cheers.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Frigidaire FRS26H7 26 Cu. Ft. Side By Side Refrigerator Built in Water / Ice Dispenser Logo
79 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
