Question about ViewSonic PJ503D Projector Lamp
The lamp is ok and i still want to use it. the screen says the lamp life is over, --how can i reset the timer and still use the same lamp? its bright is ok, the lamp costs here in argentina more than the entire projector...
4 Suggested Answers
  • 3 Answers
SOURCE: how to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Posted on Jul 23, 2008
00Steven
  • 6 Answers
SOURCE: set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Posted on Sep 27, 2008
  • 4 Answers
SOURCE: how to reset lamp timer on Pj458D
turn the projector on. open the menu. go to advanced. scroll down to the first option which should be auto source. make sure this option is checked. while on this option press right once, left twice, right 3 times, then left 4 times. another menu will appear. scroll to lamp time and push enter. this will take it back to zero.
Posted on Apr 01, 2010
Can't reset lamp
Because of this fact, Jasbo, LG has lost all future business from me.
Apr 07, 2013 | LG CF181D Projector
Hello, i would like to know if resetting the lamp timer on an LG MW60sz12 will allow you to get more time out of it?? also if it is possible, how do you reset it???
Quick answer = NO.
As projection TV lamps generally have a life somewhere between 3,000 - 6,000hrs (depending on lamp quality/type), the lamp timer is simply there to assist you in determining when the current lamp is due for replacement.
Resetting the lamp timer has no effect what so ever, on the longevity of the lamp.
The Lamp Timer Reset function is hidden within the Service menu and as such, technicians are usually the only ones who are authorised to reset the timer.
However, the following procedure has been known to reset LG lamp timers:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
5. While holding that button, press and hold the MUTE button on the remote.
6. Press and hold the ENTER (or OK) button on the TV front panel.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm
"If this has resloved your problem, please be kind enough to rate this solution and/or leave a testimonial"
Sep 19, 2011 | Televison & Video
How do you reset the lamp timer?
Here's how to reset the lamp timer:
- Press the Menu button
- Scroll down to the LAMP TIMER RESET option, then scroll right to enter
- Confirm that it is OK to reset the lamp timer by hitting the OK button.
- The on-screen menu should confirm the lamp was reset correctly
You should only reset it after you've changed the projector bulb.
Feb 03, 2011 | JVC TS-CL110UAA Projector Lamp
Projector turns on. The blue screen comes on. After the ben Q symbol disapears a warning measage comes up 2004 hrs, change bolb if not bright. Then picture disapears and the temp light comes on! Any...
hi,
its because ur lamps life comes on its end. its time to replace the lamp. after replacing u should rest the lamp timer to zero. if u have already replaced the lamp do the following,if not also.
1 Press and hold the Exit (up arrow) button on the projector for 5
seconds to display the total used lamp time.
2.Press Auto button the projector or on the remote control to
reset the lamp hour to "0".
3. Wait about 5 seconds to let the OSD disappear.
ok
Dec 22, 2010 | BenQ PB6110 Multimedia Projector
I replaces my bulb in the sony vpl-hs10 and it still will not turn on after I reset it what do I do now? the lamp light is still lite it turns on but the lamp does not project anything
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Nov 19, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
Sony vpl-hs20 cineza projector- reset lamp counter
Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
Reset lamp life counter pt-50dl54j
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
Feb 19, 2009 | Panasonic Televison & Video
Sony cineza vpl hs51 projector won't project
Something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
The lamp may not have been changed - just the timer reset - How many hours has the lamp really done - 1000, 3000, 5000?
If you know that the hours are genuine, then was the quartz bulb contaminated with a touch of oil from skin contact?
This will substantially shorten lamp life, due to the quartz going milky and opaque.
The easiest way to check, is to pull the lamp and have a look at the bulb.
If need be replace the lamp and reset the lamp timer.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS51
Dec 07, 2008 | Sony Projector Lamp for VPL-HS51
Best but repleace bulb but red light still on
So far I have entered the service menu (both menus together) then selected Lamp Replace (option 14) and then pres ok to reset. Version and Lamp (option 11) now reads Lamp life (Khr) = 8 and Lamp use (Hr) = 0.
Jan 19, 2008 | LG RU-44SZ51D 44" Rear Projection...
Open Questions:
See all ViewSonic PJ503D Projector Lamp Questions
ViewSonic PJ503D Projector Lamp Logo
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
